GL1800 Fuel filler cap "blow back" "volcano" - Steve Saunders Goldwing Forums
post #1 of 12 (permalink) Old 03-29-2012, 02:37 PM Thread Starter
Hi,
Very, VERY happy new owner of a 2012 GL1800. Last weekend we went for our first longer ride. I stopped for fuel as I was down to 1/4, and when I opened the filler cap along with a hiss came a couple cups of gasoline! I was suprised, my wife was shocked...
Has anyone else experience this?
Is there a "fix"?
Is it a problem that Honda or my dealer needs to address?
Thanks in advance.
-AL
al.ott is offline
post #2 of 12 (permalink) Old 03-29-2012, 03:00 PM
Zeke66's Avatar
That seems about normal to me Al. Nothing to worry about.
Zeke66 is offline
post #3 of 12 (permalink) Old 03-29-2012, 03:03 PM
Gregarious Greeter
SETHAN12's Avatar
Model: GL 1800
My 2005 has never done that
The cap is vented.
New bike, take it back to the dealer!!
Yesterday is for memories!
Today is for making memories!
Just livin\' the dream!!!!!
Honor above all else!!!!!
SETHAN12 is offline
post #4 of 12 (permalink) Old 03-29-2012, 04:04 PM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
It blew gas out of the tank?
If so, that's odd... Motorcycles historically have a Vacuum in the tank... In contrast, modern cars have Pressure in the tank.
My 2008 Piaggio MP3-500 has a Pressurized tank... It sometimes does the same thing as yours, actually Blowing the gas gap several feet into the air when you open it! <Blam!>
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #5 of 12 (permalink) Old 03-29-2012, 04:19 PM
Zeke66's Avatar
I misread your initial post Al, didn't see the bit about gas coming out of the tank. I thought it was just the usual hiss of pressure.
Zeke66 is offline
post #6 of 12 (permalink) Old 03-29-2012, 04:22 PM
unionjk's Avatar
Get your gas cap checked.
The valve in the cap is designed to keep a slight vacuum in the tank, but then allow air into the tank when that pressure gets too high, it also allows pressure to escape through the same valve as cold gas heats up and expands (or starts boiling).
kind of the same way that the radiator cap works.
My gas cap started making a loud buzzing or screaming noise after the bike was parked, A couple of rounds with some cleaner in the valve inside the cap stopped that though.
'RIDE TO BE SEEN'
Most common quote from a cager after killing a motorcyclist is?
"I never saw him".
unionjk is offline
post #7 of 12 (permalink) Old 03-29-2012, 07:32 PM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
Welcome to the forum al.ott
And congradts on the new wing.
The winter fuel mix being sold still, boils in the tank when it is warm temps out and a hot engine from riding in traffic. Thus will cause the extra pressure in the gas tanks right now till they switch to the summer blend. There are a number of posts on this around the country from the unusually warm winter and many getting their bikes out for a ride in the warm weather.
Tell the dealer about it, they may check the cap to be sure it is functioning properly.
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #8 of 12 (permalink) Old 03-29-2012, 10:00 PM
MichiganWing's Avatar
Model: 2007 Gl1800 HPN
Never heard of such a thing..and I ride in Colder than you can believe Michigan, where the weather changes often.
Al..that IS a problem!
Shiny Side Up !
Jim
MichiganWing is offline
post #9 of 12 (permalink) Old 03-29-2012, 10:31 PM
Still Learning
newday777's Avatar
I started riding in NH in the 70's and was there(NH) last fall for the 2' snow storm and then rode back here mid Nov, arriving Dec 1st. I know what cold riding is bro, and I do agree he needs to go to the dealer.
As far as the posts go, do a forum search. Lots in the past couple weeks.
https://www.goldwingfacts.com/forums/...re+in+the+tank
Stu
Previous bikes
post #10 of 12 (permalink) Old 03-30-2012, 10:59 AM
knklehd1's Avatar
Model: gl1800
I would bring it back to the dealer as mentioned something is wrong for sure your building up way to much pressure.
Winter blend will release more fumes as its designed to do as its not made for warmer weather as mentioned.
And they didn't even start making summer blend yet,cant wait to see the price per gallon this summer.:ac tion:
I have done so much with so little,I can do anything !!
08 gl1800
knklehd1 is offline
"Rockin The Wing"Center Stand, "What Works For Me" Tom81Wing Goldwing Technical Forum 1 03-28-2010 06:22 PM
Anyone got Nextels "Direct Connect" or Sprint's "Ready Link"? Nightrider1 Miscellaneous Forum 12 11-19-2008 01:45 PM
NASCAR "Gopher Cam" called "DIGGER" 96aspencade Miscellaneous Forum 3 03-02-2008 07:52 PM
Is your headlight "on" in "park". I am installing aftermarket ignition switch. newbiker Goldwing Technical Forum 4 12-05-2007 08:42 PM
"Holy Guacamole!" It's a talking "Crocodile Hunter" AZgl1800 Miscellaneous Forum 1 01-20-2007 10:16 PM
