GL1800 CD Input Button not Working - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 04-09-2012, 04:27 AM Thread Starter
wilkoi's Avatar
Year: 2008
Make: Goldwing
Model: 2008 90,000 Miles
I have a 2008 wing. Did a small group ride today, 4 bikes. Left a burger joint, sound from Ipod mounted in trunk would not come on. When you hit the weather, FM, AM, and Aux input buttons there is a low tone beep and the input appears on the nav screen. But pressing the CD input no sound and no switching to that input. Got home, sprayed input button with silicone, no good. Any ideas?
Ride long and often.
wilkoi is offline
post #2 of 4 (permalink) Old 04-09-2012, 05:14 AM
BenMilner's Avatar
The button is probbaly gone bad Lew. The same thing happened to my AUX button and I had to remove the audio unit and open up the button. It was tricky top open, the button is made of brittle plastic and the tabs break off real easy.
Inside the switch the contacts were dry as a bone and some rust was in there. I cleaned it up and put some silicon grease inside and that fixed it.
BenMilner is offline
post #3 of 4 (permalink) Old 04-09-2012, 05:19 AM Thread Starter
wilkoi's Avatar
Year: 2008
Make: Goldwing
Thanks for the reply, that was my line of thinking, now I know, again thanks.
wilkoi is offline
post #4 of 4 (permalink) Old 04-09-2012, 05:23 AM
Try disconnecting the reconnecting the interface module.
CD Input Button Not Working wilkoi General Motorcycle Discussion Forum 0 04-08-2012 02:49 PM
stuck GL1800 cruise button........reverse button MECHANICASE Goldwing Technical Forum 11 03-06-2011 06:55 PM
GL1200 starter button not working dvjoiner Goldwing Technical Forum 3 08-20-2010 05:40 AM
Starter Button Not Working Aspengold Goldwing Technical Forum 27 01-09-2009 07:21 PM
GL1800 Navi - Button Lights Not Working RandyWharton Goldwing Technical Forum 2 06-18-2008 04:27 PM
