How to remove carburator on gl1100 aspenade - Steve Saunders Goldwing Forums
post #1 of 14 (permalink) Old 04-11-2012, 05:31 PM Thread Starter
I have the intake manifolds off. The carburator moves, but there is like packing on top. It looks as if it has to be removed before it will slide out. Does the gas tank have to be removed ?
jhood41591 is offline
post #2 of 14 (permalink) Old 04-11-2012, 05:57 PM
jackjohn's Avatar
Hi JHood and welcome to the forum. Gas tank does not have to come out. Remove air filter housing and associated hoses, disconnect throttle cables from the bell crank. Remove the intake elbows. Remove the vacuum towers from the right side, then the whole array will come out the left side. (With some work)
Jack
2012 GL1800A
2004 GL1800A Sold
1982 GL1100I Sold
1975 GL1000 Sold
1974 CB450 Sold
jackjohn is offline
post #3 of 14 (permalink) Old 04-11-2012, 06:00 PM
William_86's Avatar
Model: GL1500 Aspencade
as jackjohn said, the air filter housing has to be removed, then the right side carb caps have to be removed too, then you pull the carbs to the left and disconnect throttle cables and continue to remove them to the left side.
i almost forgot, in some cases (most) there is a coolant pipe that bolts on top of the head between the intakes on the left side, it has to be removed aswell.
William_86 is offline
post #4 of 14 (permalink) Old 04-11-2012, 06:21 PM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
Welcome to the forum jhood41591
Do you have the repair manual for your bike? That is your #1 tool to have and use.
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #5 of 14 (permalink) Old 04-11-2012, 06:23 PM
Still Learning
newday777's Avatar
Where do you get this from William? I never had to remove that tube.
Stu
Previous bikes
post #6 of 14 (permalink) Old 04-11-2012, 06:54 PM
William_86's Avatar
i had to remove it while removing the carbs on a friends 1100 it was the only way to get then out and i believe someone on this forum suggested me to do it.
post #7 of 14 (permalink) Old 04-11-2012, 08:09 PM
mainwiz3's Avatar
Year: 1989
Make: GL1500
Model: Aspencade
Send a message via Yahoo to mainwiz3
when I had my 1100's I never removed the coolant tubes for removing the carbs.
Tell me it can't be done and I will make it happen if I can make or get the parts made
Previous bikes
76 GL 1000
77 GL 1000
81 Interstate (Daily Bike)
81 Interstate ( Future standard with some twists)
82 Aspencade (restoration Project been sitting since 95 possibly trike)
Current
89 GL1500 Aspencade
mainwiz3 is offline
post #8 of 14 (permalink) Old 04-11-2012, 08:23 PM
You just didn't hold your mouth right, never heard of anyone removing that tube to do it.
post #9 of 14 (permalink) Old 04-12-2012, 06:32 PM Thread Starter
Thanks for all the quick replies. Yes I have a repair manual, it says the same things you have replied, except it says open the glove box and remove the tool kit.where is the glove box? The box directly in front of me when sitting on the seat contains the fueling cap and the compressor for air shocks. I didnt mention it has air shocks.
Thanks again to all who responded.
post #10 of 14 (permalink) Old 04-12-2012, 06:32 PM Thread Starter
GL1100 carburator jeep123 Goldwing Technical Forum 4 01-21-2011 10:03 AM
GL1100 carburator problems gsolano Goldwing Technical Forum 5 01-09-2010 10:02 PM
1987 aspenade Firehouse 02 Goldwing Technical Forum 6 05-17-2007 07:38 AM
Rare GL1100 Carburator Covers stretrod48 General Motorcycle Discussion Forum 0 04-19-2006 08:40 PM
carburator gl1100 poppa bear Goldwing Technical Forum 13 09-23-2005 07:18 AM
