GL1100 clutch springs - Steve Saunders Goldwing Forums
post #1 of 13 (permalink) Old 04-25-2012, 09:38 PM Thread Starter
Cooter81gl1100's Avatar
Model: 81 GL1100I
I have installed a new to me engine in my 81. The clutch slips when you are onto the throttle hard. I have a new set of springs sitting on the bench just wondering if I can swap them out without removing the engine again. I was looking at it and i think I should just have to undo the cover and swap out the springs one at a time should I not?? Will likely curse some trying to get my hand in there but would be easier then pulling engine again. I also have the rear tire off right now to have new one installed. Giving me more room to lay on the floor
Cooter81gl1100 is offline
post #2 of 13 (permalink) Old 04-25-2012, 09:43 PM
Cyclebusters.com
Cyclebuster's Avatar
Year: 67, 68, 69, 70, 71, 72, 73 74, 75, 76, 80, 81, 82, 83
Make: Honda, Suzuki Kawasaki, Triumph BSA
Model: Standard, Interstate, Aspencade.
its pretty wide open if you pull the swing arm. you should take it apart and look it over. have you verified the cable is not hanging up?
Current toys
69 BSA Rocket 3, 69 H1, 68 T500 Cobra, 71 Trophy 650, 72 CB750, 73 CB750, 74 CB750, 76 CB750, 72 S2/500 hybrid, 81 Gl1100 Standard, 71 A1SS, 71 H1, 78 SR500, 81 Honda MB50, 75 GL1000, 76 GL1000, 76 Goldwing Gl1000 LTD, 82 GL1100I, 82 GL1100A, 83 GL1100 Standard.
Cyclebuster is offline
post #3 of 13 (permalink) Old 04-25-2012, 10:10 PM
Silicon Sam's Avatar
Model: 1997 GL1500 SE
Absolutely you can change the springs real easy. You remove the clutch cover, then the center nut holding the pressure plate (watch that trick tabbed washer...), then remove the 6 bolts holding the pressure plate to the clutch basket. There are your 6 springs. 2 bolts are shouldered differently, so keep track of which holes they go in.
While you're there, it'd be wise to replace 30+ year old clutch discs too. Buy some EBC or Honda plates, don't buy the Chinese plates out in the market.
Just get you bike up in the air, and you can reach the clutch cover from the sides and underneath the bike. Don't need to remove anything in the rear for access.
About the only thing in the way is some hoses from up top.
Silicon Sam is offline
post #4 of 13 (permalink) Old 04-26-2012, 05:40 AM
Mr Magic Fingers's Avatar
Hey Cooter,
Yes... you can do it on the bike without issue. You can't do the springs "one at a time" though.
Just be VERY careful... the "star plate" shown here is very fragile. Loosen up each bolt just a little in a staggered pattern just like you would a tire rim to prevent stressing that fragile aluminum. Just a little at a time. Those plates are getting rare so I hear. NOTE the location of the different colored bolts.
I didn't remove the tire or swing arm. I have pretty large hands too. It can be tricky but very doable. The bike was on the center stand IIRC.
____
Please visit
Mr Magic Fingers is offline
post #5 of 13 (permalink) Old 04-26-2012, 05:41 AM
You will be left with this... Simply pluck and replace those springs... No need to go further if you only doing your springs.
____
Please visit
post #6 of 13 (permalink) Old 04-26-2012, 05:42 AM
This was the difference in my clutch springs from 30 years of use, 30 years as far as I know...
Best of luck.
Tim.
____
Please visit
post #7 of 13 (permalink) Old 04-26-2012, 05:50 AM
beertap tom's Avatar
Good pictures Tim, thanks.
beertap tom is offline
post #8 of 13 (permalink) Old 04-26-2012, 06:05 AM
No Problem. Your WELCOME!!
____
Please visit
post #9 of 13 (permalink) Old 04-27-2012, 10:28 PM
Is that a wheel bearing in that picture of the clutch?
Past bikes. Hodaka 125 combat wombat, 197? Bultaco 370, 1975 CB500T, 1978 CB750SS, 1981 CBX, 1983 CB1000C,
goldminer is offline
post #10 of 13 (permalink) Old 04-27-2012, 10:38 PM
I too think you should at least take a look at the plates. When my clutch started slipping, it wasa brokendamper plate.
GL1100 clutch cable too much free play - Clutch stuck? roehlerich Goldwing Technical Forum 10 10-22-2010 06:32 PM
I REALLY NEED HELP WITH MY GL1100 SPRINGS ASAP THEBIGRED1 Goldwing Technical Forum 6 06-13-2010 07:10 PM
Springs, Springs, Springs... I need carb springs this spring! Mr Magic Fingers Goldwing Technical Forum 3 04-29-2010 08:27 AM
progressive springs gl1100 Phils a winger at last Goldwing Technical Forum 3 05-23-2007 01:34 AM
Clutch slipping, will new springs help? N5HQ Goldwing Technical Forum 25 05-12-2007 11:24 PM
