GL1500 Top-gear acceleration - Steve Saunders Goldwing Forums
post #1 of 8 (permalink) Old 05-13-2012, 12:15 AM Thread Starter
Send a message via MSN to johnocooper Send a message via Yahoo to johnocooper
I hesitate to bother this group again; On a GL1500 should there be any hesitation or delay however slight when you twist the throttle hard in top-gear from say 50mph or 60mph? Even while my GL1500 has been gone through by three mechanics now it still has a slight hesitation when accelerating in top-gear. This is most pronounced if you attempt to accelerate very quickly, immediately open the throttle completely from 50 or 60mph.
I drove my GL1800 today and it has no hesitation whatsoever.
johnocooper is offline
post #2 of 8 (permalink) Old 05-13-2012, 12:45 AM
Biker John's Avatar
Model: GL 1800
Sounds likethe accelerator pump in the carb isn't working.
2006 GL1800
Dark Red
DarkSider
Michelin Alpin PA3 195/55/16 RF
Biker John is offline
post #3 of 8 (permalink) Old 05-13-2012, 01:10 AM
post #4 of 8 (permalink) Old 05-13-2012, 07:10 AM
galaxyhunter's Avatar
Model: 2000 Aspencade
Wouldn't that show up when ever one twisted the throttle no matter what gear your in?
I remember back to my first car. It had a Rochester 2 barrel carburetor. I was working on the carb & with out knowing it, knocked off the little clip that held the accelerator pump rod. I was out driving & the rod worked its way out & fell off the linkage. From that point on I had a MAJOR hesitation & when I got to the next stop sign, I couldn't take off. I idled through the intersection to the shoulder of the road, looked at the carb and put the rod back into the linkage. I wasable to drive home where I put another retaining clip on it.
Carl
Honorary Rhino
NASSIR 6 - NASSIR 7
NASR 10 - NASR 11
NASR 12 Host in Galena
old bikes:
71FX Super Glide
86 Aspencade
galaxyhunter is offline
post #5 of 8 (permalink) Old 05-13-2012, 07:30 AM Thread Starter
Important fact I should have included; it accelerates perfectly in lower gears, idles perfectly, starts immediately.
post #6 of 8 (permalink) Old 05-13-2012, 07:53 AM
gumbyred's Avatar
Model: 2006 Level 2 Gold Wing
Maybe add a little Seafoam, and just ride it more. Have you been parking it more in favor of the 1800?
gumbyred
gumbyred is offline
post #7 of 8 (permalink) Old 05-13-2012, 09:18 AM
perhaps its just the extra power of the 1800 you are missing in the 1500. Also the 1800 is injected.
i would think you are down in the rpm range when running 50 to 60 is it happy with a rollon ay 70 mph in top gear
wilf
79 gl1000 dresser
80 gl1100I now naked
90 1500 full dress
wilf is offline
post #8 of 8 (permalink) Old 05-13-2012, 12:12 PM
It aint rocket science
DriverRider's Avatar
Model: The best
Not always true, different throttle openings have an affect on the ability through the pump stroke to deliver the extra fuel needed. A hesitation on acceleration with an otherwise well running motor would be a lean condition.
A complete check of the pump assembly is in order. A good steady stream of fuel should appear at the nozzles of the air horn. Diaphragm, check valves, O rings and linkage all contribute to the operation.
If everything is OK, the advanced tuner could possibly get a better pump shot through a stroke adjustment. It is important to get an accurate starting point with a measurement to be able to return to the original setting through trial and error. Adjustment would be made here.
JD
edit: These carbs are very sensitive to change and there are a lot of variables involved.
J.D.
Internet myth buster
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
DriverRider is offline
83 GL 1100 no acceleration in 4th & 5th gear, pulse generator??? klingtut Goldwing Technical Forum 14 05-10-2012 01:07 AM
Faster acceleration/ faster top speed, GL1800 cwhonda Goldwing Technical Forum 23 05-29-2011 05:49 AM
top gear space shuttle EDDIE W Fun Forum 10 02-22-2007 08:16 PM
Top Gear Swaggerman Miscellaneous Forum 0 09-29-2006 05:19 PM
Poor 5th gear acceleration fgh Goldwing Technical Forum 7 05-12-2006 11:49 PM
