10 or 15 wt fork oil with progressive springs - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 05-17-2012, 08:11 AM Thread Starter
SmartBiker's Avatar
right now im using 10wt oil in the forks with progressive springs.
filled to 14.5" from top of fork cap with air valve removed.
seems kinda bouncy but supple
was wonderin what 15wt would do with the same fill amount?
<<<<---my other bike-Yamaha GTS 1000 (lefty)
1994 GL1500SE pearl atlantis blue with an 1998 motor (i aint tellin)
1999 Suzuki TL1000R (hooligan)
i do tire changes in the chicago area...773 469 2932. feel free to call or text me for an appointment or details
Mr. Vern
SmartBiker is offline
post #2 of 5 (permalink) Old 05-17-2012, 08:21 AM
GEROWING's Avatar
Hi, usually 10w oil with progressive springs is the perfect ride, while 15w with progressive might make for a stiffer ride. i would probably go with the 10w and change to 15w on next service, you can also play with the amount of oil you put into the forks.
FASTEST COLOUR I THINK
GEROWING is offline
post #3 of 5 (permalink) Old 05-17-2012, 08:59 AM
knklehd1's Avatar
Model: gl1800
I just put in progressive springs and went with the 15wt oil,to me its a good ride.
I have done so much with so little,I can do anything !!
08 gl1800
knklehd1 is offline
post #4 of 5 (permalink) Old 05-17-2012, 10:03 AM
Just another ORF!
Dusty Boots's Avatar
Model: 92 1500 Aspencade
You could always try the 15wt oil, filled to the same level .... if you find that a bit too harsh/stiff, try subtracting an inch of fluid and retest. Or .... keep with the10w, but add an extra inch. If that doesn't do it for ya, go with a 15wt.
You should be able to 'fine tune' it to your liking by adding/subtracting amount/weight of oil
- just another Rider
Dusty Boots is offline
post #5 of 5 (permalink) Old 05-17-2012, 10:10 AM
Jason's Avatar
Dusty Boots wrote:
You could always try the 15wt oil, filled to the same level¬*¬* ....¬*¬* if you find that a bit too harsh/stiff, try subtracting an inch of fluid and retest.
That's what I did. 15w was a bit hard until I removed 25cc, it was perfect for me after that.
Jason
Jason is offline
GL1500 fork oil weight with progressive springs??? pippomaranga Goldwing Technical Forum 9 12-02-2011 09:16 AM
GL1500, fork oil progressive springs Lightin Goldwing Technical Forum 29 06-25-2011 04:14 AM
Progressive fork springs gl1100. how much oil? knowbuddy Goldwing Technical Forum 8 03-28-2010 01:47 PM
Progressive Springs & Fork Oil (re-post) 93A GL1500 Walt Phillips Goldwing Technical Forum 5 02-23-2007 10:13 PM
Changing fork oil with Progressive Springs installed mvasil54 Goldwing Technical Forum 11 04-22-2006 11:41 PM
