GL1200 ignition system - Page 2 - Steve Saunders Goldwing Forums
post #11 of 20 (permalink) Old 06-22-2012, 06:08 PM
pdbro wrote:
pretty sure PGs are N/A new for the 1100, if 1200 is the same deal, i'd get spares
The 84 is the only 1200 with the pulse generators in the rear like the 1100 and although they have the same function they're not interchangeable. Plus they're N/A for the 84 too.
Ken Bergen is online now
post #12 of 20 (permalink) Old 06-22-2012, 06:16 PM
tricky's Avatar
Year: 1985
Model: 85 Aspencade
Don't know how long they will be available but just this week I ordered and received a set of pulse generators for a 1200. C$105 + taxes
tricky is offline
post #13 of 20 (permalink) Old 06-22-2012, 06:28 PM
That would be for the 85-87. For the 1100 and 84 1200 they're NLA.
post #14 of 20 (permalink) Old 06-22-2012, 08:01 PM
tricky's Avatar
Year: 1985
Model: 85 Aspencade
Yes forgot to mention 85 Aspy
tricky is offline
post #15 of 20 (permalink) Old 06-22-2012, 11:19 PM
Vintage Rider
Model: none at present
While the ignition system is probably ok, the 1200 is well known for charging system problems. I would check the stator and the R/R per the manual, and check ALL the white plastic connectors in the wiring, from the stator to the R/R. If you find anything burned, cut out all the connectors and solder the wires together. Also check the R/R itself for excessive heat. It is normal for it to run pretty warm, but it it is hot enough to burn you from just a momentary touch, something is wrong. Since you have an '84 with a 350 watt stator, hopefully you will not have the problems I had with my '85 LTD with the 500 watt stator.
"New vehicles move the body. Old vehicles move the soul. Vintage forever"
"Obsolete does not mean it is not any good, it just means it is not made anymore"
"The simpler the better"
Save the environment. STOP the developers.
PGR member since 2007
JerryH is offline
post #16 of 20 (permalink) Old 06-24-2012, 07:43 AM Thread Starter
casetractor's Avatar
Model: GL1200A
Thanks for all the replies folks, really appreciate it!
casetractor is offline
post #17 of 20 (permalink) Old 06-24-2012, 08:23 AM
jobe05's Avatar
Model: 1500 & 1800
Ken Bergen wrote:
As gaswing said just ride it.
Your ignition components have lasted for 28 years and there's no reason to expect them to fail now.
Good suggestions all, but I like this one the most.......
There are simple maintenance items that you could look out for but I wouldn't start replacing parts just because they might fail. Go ride! Enjoy!
Honorary Rhino.......
jobe05 is offline
post #18 of 20 (permalink) Old 02-14-2013, 03:44 AM
Senior Guru
Goldwinger1984's Avatar
Just want to mention that 1984 GL1200 pulse generators are in fact mounted in a difficult to access location on the engine (requires swing arm removal), but, the failure rate of 1984 pulse generators are almost non existent compared to the failure rates for 85 - 87 pulse generators which are mounted directly in the intense heat of the radiator. Not certain, but, I'm guessing the reason for the better lifespan of the 84 pulse generators could be in their location which is in a much cooler spot behind the engine.
Goldwinger1984 is offline
post #19 of 20 (permalink) Old 02-14-2013, 11:21 AM
Fastymz's Avatar
Model: 1988 GL1500
Sorry just jumping on here, I too just got an 84 and like yourself I'm planning a big ride but to Seattle this summer. I too have been trying to figure out what else to replace and I have just done the alt conversion too. I replaced the maintance items,belts, hoses, plugs, coolant, t-stat,oil and some wires. Other then that I need to get it on the road and see what else it needs or doesn't?
Ron
1988 GL1500 76000miles
1986 Honda 700F VFR 39000miles
Fastymz is offline
post #20 of 20 (permalink) Old 02-14-2013, 01:27 PM
Senior Guru
Don't forget to check brake pad thickness, change clutch and brake fluid and make certain that you properly grease the rear wheel splines with moly 60 lube. Brake hose condition ( I use braided stainless steel hose) because 30 year old rubber brake hose may have cracks and weak spots. Make sure you have extra fuses for all electrical circuits and it would be wise if you disassembled, cleaned and tightened all electrical connections, because, doing it on the side of the road in the dark is a real pain. Thank goodness Tricky was riding with me when my electrical connections failed as it took two people to fix the darn thing on the roadside at night. You should also check all wheel bearings for smoothness, if any roughness felt then change the bearings before you leave. Final drive lube is often overlooked, but, without proper oil level the driveshaft can fail. This will get you started as I am certain there are more items that you can check. Good luck.
GL1200 Ignition Problem mcherry80 Goldwing Technical Forum 25 10-05-2012 11:36 AM
1988 GL1500 Ignition or Charging System 69BuickGS Goldwing Technical Forum 9 08-09-2012 06:16 PM
GL1200 Ignition just winging it Goldwing Technical Forum 5 09-15-2010 03:46 PM
Ignition System GL1200 Interstate tcbronson1 Goldwing Technical Forum 3 04-27-2007 10:08 PM
GL1200 Ignition switch....HELP gdwales Goldwing Technical Forum 11 12-15-2006 01:02 AM
