GL1100 low compression - Steve Saunders Goldwing Forums
post #1 of 19 (permalink) Old 06-28-2012, 06:27 PM Thread Starter
I have a 1981 gl 1100, I have been having problems with number 3 cylinder, I was getting 150psi on the first compresion test then sudenly on a second test there was no compresion I ground the valves, and tested again but only get 90psi, I have also replaced the head gasket, im not very machanicaly minded can anyone help please
mad dog 60 is offline
post #2 of 19 (permalink) Old 06-28-2012, 07:21 PM
How long between the first and second compression tests? Was it having a problem when it had 150PSI? Did you see a problem with a valve and what did the cylinder and piston look like when you had it apart?
post #3 of 19 (permalink) Old 06-28-2012, 10:55 PM
Hi Mad Dog, and welcome to the forum.
We will need more info.
Why did you grind the valves?
post #4 of 19 (permalink) Old 06-29-2012, 11:34 AM
chaztic's Avatar
Wassup guys.. woo woo!! seccond post.. no compression equils a valve staying open all the time, or worse.. the open valve is hopefully just not adjusted properly.. (the or worse) prob has to do with the valve grind or a bent valve.. here's hopin' laters,chuck
chaztic is offline
post #5 of 19 (permalink) Old 06-29-2012, 05:59 PM
litfuse's Avatar
Model: GL1100I
Welcome to the forum Mad Dog 60!
150 psi is a pretty good compression. You need to open the throttle wide open when doing a compression check. Seeing as how you did some valve work you need to adjust the valve stem clearance.
You also have hardened valve face,the most that needed to be done was lap them in with some lapping compound.
Did you find the oil control orifice at the top of the jug,in between the cylinder?
Keep us posted on everything,we will get you thru it.
litfuse is offline
post #6 of 19 (permalink) Old 06-29-2012, 06:04 PM Thread Starter
I ground them as they were leeking it was leeking at the exaust valve onces they were ground the presure went from zero to 90 but cant get it above that, and thanks for the welcome, its nice to finaly own a goldwing only hope I can get the problem fixed
post #7 of 19 (permalink) Old 06-29-2012, 06:19 PM Thread Starter
the first test was after I turned the bike over for the first time when I bought it, it only showed 40psi that was when I first ground the valves preasure went up to 150 then when I turned it off and back on tested again and presure was zero, I took the head off and filled it with break cleaner it leaked at the exaust port, I regroung the valves and the leek stoped but this time the presure only went to 90
post #8 of 19 (permalink) Old 06-29-2012, 06:24 PM
Valves were leaking? How many miles on the bike?
Honda valves shouldn't be ground.
post #9 of 19 (permalink) Old 06-29-2012, 06:43 PM Thread Starter
it says 45,000 it was off the road for the last 15 years as far as I know the the top of the piston was black if that helps any, it was a paste and a sucsion stick I used to do them, I asumed that ment I was grinding them if not whats the corect term for it please
post #10 of 19 (permalink) Old 06-29-2012, 07:08 PM
lapping,
if a valve sticks, that could give you compression issues
82, going over it
had a hog in there for a bit but basically,
back in the saddle after a ~ 24 year break,
at the time, had an oncoming made a left turn deal
pdbro is offline
GL 1200I low compression bwills6 Goldwing Technical Forum 15 03-25-2012 07:24 PM
Low Compression GL1200 TominDallas Goldwing Technical Forum 12 09-29-2010 01:30 PM
GL1200 low compression pms Goldwing Technical Forum 9 04-03-2010 09:16 AM
Low Compression thessler Goldwing Technical Forum 17 12-05-2007 06:49 PM
Low compression, GL1100 LD Hack Goldwing Technical Forum 11 03-18-2006 08:12 PM
