Soft rear break pedal GL1500 - Steve Saunders Goldwing Forums
post #1 of 13 (permalink) Old 06-30-2012, 11:06 AM Thread Starter
toy4rick's Avatar
Hey Gang,
I seem to get quite a bit of air in my rear break pedal that can be bled out through the front caliper only, no air comes out from the rear caliper. The pedal firms up real well then about 2 months later, the air is back.
No fluid along the lines or at any connectors that I can find. Replaced the break line to SS about 3 years ago, can't remember if this started before or after the SS line replacement.
So how does air get in when this is a positive pressure system and no fluid appears to be coming out?
For the life of me, I can't figure this one out
TIA
Toy4Rick
It never rains in Southern California, so we ride
1997 SE Pearl White
toy4rick is offline
post #2 of 13 (permalink) Old 07-01-2012, 07:13 PM Thread Starter
toy4rick's Avatar
Really, nothing from this very knowledgeable and helpful group of fellow riders?
Toy4Rick
1997 SE Pearl White
toy4rick is offline
post #3 of 13 (permalink) Old 07-01-2012, 07:33 PM
I had a clutch like that. It was the master cylinder.
Had it rebuilt it a couple times, bled it a few times...
...finally went to the junkyard and bought a used M/C from an '86 and put it on without doing anything but bleeding. It is still working perfectly for nearly 200K miles.
post #4 of 13 (permalink) Old 07-01-2012, 07:38 PM
mowerdoc's Avatar
don't have any answer but give them some time everybody getting ready for nassir5
mowerdoc is offline
post #5 of 13 (permalink) Old 07-01-2012, 07:38 PM
Lost on this *****
Winger77's Avatar
Model: 1997 Aspy
Send a message via AIM to Winger77
That one is puzzling . I recently had problems with my rear pedal going soft (that don't sound right ) after changing tires and clean/lube the caliper pins. Just couldn't get the pedal to stiffen up at all. So I replaced the master cylinder with a new one and all is well again.
That's as far as my expertise goes. Can't explain why it stopped working.
The things I liked,,,,I\'ve tried em twice!
You have to be a little Crazy,,,,,, or else you\'ll go Insane.
Winger77 is offline
post #6 of 13 (permalink) Old 07-01-2012, 09:03 PM Thread Starter
toy4rick's Avatar
MC seems an unlikely suspect since I never get any air out of the rear caliper, only the front.
I have bled this about 4-5 times, is it possible that I just haven't gotten all the air out yet?
I have speed bleeders on each caliper, let me ask this, should they be fully opened or partially opened to get the best bleed?
Toy4Rick
1997 SE Pearl White
toy4rick is offline
post #7 of 13 (permalink) Old 07-01-2012, 09:19 PM
Well, I gave it my best shot.
post #8 of 13 (permalink) Old 07-01-2012, 09:28 PM
Busdriver
busdriver's Avatar
Year: 1990
Model: GL1500, 172,000 KM
Speed Bleeder instructions say open 1/8 - 1/4 turn.
busdriver is offline
post #9 of 13 (permalink) Old 07-01-2012, 10:00 PM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
Rick
The SS line, is that from the master to the rear caliper? Or still the steel line off master cyl?
Have you had a leaking battery? If so chevk the line out of the master cyl.
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #10 of 13 (permalink) Old 07-01-2012, 10:13 PM
A couple of possibilities come to mind. First would be a master cylinder problem. A defective master piston cup could suck air into the system when releasing the pedal. If this was coupled with a plugged small port air could build up in the system. If it were my bike I'd check the small port in the master cylinder first and check that there's no sign of any fluid leak around the area where the piston rod comes out of the master cylinder. One other lesser possibility is that some people have had problems with speed bleeders in that they can suck air back into the sytem around the threads.
Foot brake pedal soft, GL1500. Wyo Winger Goldwing Technical Forum 5 12-17-2010 10:46 PM
Rear break pedal rider 76 Goldwing Technical Forum 2 07-15-2010 04:34 PM
Rear break pedal, GL1500 scoot scoot Goldwing Technical Forum 1 03-06-2010 09:41 PM
Adjust Rear Break Pedal rak69 General Motorcycle Discussion Forum 4 05-02-2008 10:48 AM
Rear break pedal distance toy4rick Goldwing Technical Forum 3 04-24-2006 07:09 PM
