GL1500SE Tire problem - Steve Saunders Goldwing Forums
post #1 of 22 (permalink) Old 07-12-2012, 08:10 AM Thread Starter
SamH's Avatar
I'm sure this has been covered however.........I would appreciate feedback on riding on a tire that has been plugged on the contact surface.
Several miles from home (and convenient services) I picked up a stray #6 wood screw.
For numerous (somewhat sound) reasons, I chose to plug the (rear) tire at the scene, re-inflated and continued the trek home albeit at a somewhat slower speed.
The question is....Should I wait on the replacement OR is it safe to continue riding in the interim? There is approx 40-45% tread life remaining on the Dunlop Elite3
Sam Hegler
SamH is offline
post #2 of 22 (permalink) Old 07-12-2012, 08:22 AM
awingandaprayer's Avatar
Year: 1990
Model: 1990 gl1500SE
If it's holding air, I'd ride it!
Tired of people pulling out in front of you? Get a white helmet!
awingandaprayer is offline
post #3 of 22 (permalink) Old 07-12-2012, 08:25 AM
Anti-Guru
satan's Avatar
Model: '06 GL1800
Rear ... ride it - just pay a bit more attention to pressures and dump the tire when you start to feel squirrely in a constant radius turn.
satan is offline
post #4 of 22 (permalink) Old 07-12-2012, 08:28 AM Thread Starter
SamH's Avatar
Certain no offense intended but..... considering your "handle" (awingandaprayer), your reply comes as no surprise. LOL
Sam Hegler
SamH is offline
post #5 of 22 (permalink) Old 07-12-2012, 08:32 AM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
Rope type plug or mushroom type plug?
Many have posted that they run with a plug. Just keep a close watch visually of the plug and more importantly, air pressure before each ride.
Low air pressure is the major cause of tire failure, faster tread wear, in extreem heat, blow outs happen as the tires gets hotter faster, expanding the air in the tire beyond max pressure rating. So keep closer watch on it.
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #6 of 22 (permalink) Old 07-12-2012, 08:39 AM Thread Starter
SamH's Avatar
A Dynaplug got me to a shaded area but proved too small resulting in a slow leak. I replaced it with a small cord type. Lots of glue that was set afire before inserting & left to cool before inflating.
Sam Hegler
SamH is offline
post #7 of 22 (permalink) Old 07-12-2012, 09:05 AM
Still Learning
newday777's Avatar
Well, if it leaks, take tire tire off and have a vulcan patch put on from the inside.
Stu
Previous bikes
post #8 of 22 (permalink) Old 07-12-2012, 09:24 AM Thread Starter
SamH's Avatar
Stu, the larger cord plug does not leak. The psi is same as when inflated. For clarification.....the simple, easy to use Dynaplug was smaller than the hole but much easier to use on the side of the road than the conventional plug.
My concern is the unknown hazards involved in riding with a plug in the tire
Sam Hegler
SamH is offline
post #9 of 22 (permalink) Old 07-12-2012, 02:23 PM
Still Learning
newday777's Avatar
Just leakage.
Stu
Previous bikes
post #10 of 22 (permalink) Old 07-12-2012, 02:28 PM
Gregarious Greeter
SETHAN12's Avatar
Model: GL 1800
If you feel safe riding with a tire plug, then that is all that matters.
If it concerns you in any way, then change it.
I have found through my life, thatif something bothers me and I do nothing about it, the worst usually happens.
Yesterday is for memories!
Today is for making memories!
Just livin\' the dream!!!!!
Honor above all else!!!!!
SETHAN12 is offline
'97 GL1500SE Clock problem... ghostvet Goldwing Technical Forum 13 05-26-2012 06:19 PM
New tire install causing electrical issues on GL1500SE charz Goldwing Technical Forum 12 05-04-2010 02:08 PM
ELECTRICAL PROBLEM GL1500SE MINTY Goldwing Technical Forum 14 04-07-2010 08:20 AM
GL1500se restart problem tuxcido Goldwing Technical Forum 6 10-19-2008 09:22 AM
GL1500SE Intercom problem wizard_of_odds Goldwing Technical Forum 3 09-30-2005 06:24 PM
