Tail Light on GL1200 dash panel - Steve Saunders Goldwing Forums
post #1 of 15 (permalink) Old 07-28-2012, 07:46 PM Thread Starter
asitis's Avatar
My tail light lighton my 85 Aspencade dash comes on about once every week or two and goes off in about 5 to 10 min. Sometimes it want go off till i shut the engine off and restart it. Have checked all tail lights and brake lights at these times and all are working fine. The light causes no more problem than just comming on every now and then. Any suggestions?
1985 Aspencade that is mostly original
asitis is offline
post #2 of 15 (permalink) Old 07-28-2012, 08:40 PM
glhonda's Avatar
The signal is sent by the taillamp warning unit. Possible bad unit. Unplug and plug the connection a few times. May be dirt and corrosion. Am I correct in assuming the taillights all function correctly at time of incident?
glhonda is offline
post #3 of 15 (permalink) Old 07-28-2012, 11:54 PM
CrystalPistol's Avatar
You haven't replaced tail lamps with LEDs have you?
...(Candy Spectra Red )
CrystalPistol is online now
post #4 of 15 (permalink) Old 07-29-2012, 05:53 AM
AJ1500's Avatar
spray some wd40 into the ign switch and it should stop the prob after a few key turns
97 1500 SE
Dark Side # 1522
USCA # 8913
GOODYEAR FUEL MAX 175 60R16
Pilot Activ 130/70 18
Just getting started
AJ1500 is offline
post #5 of 15 (permalink) Old 07-29-2012, 07:38 AM Thread Starter
asitis's Avatar
No LEDs. the ones I bought are dimmer than my 1157s
asitis is offline
post #6 of 15 (permalink) Old 07-29-2012, 07:40 AM Thread Starter
asitis's Avatar
Thanks, will try. Can't get any simpler than that
asitis is offline
post #7 of 15 (permalink) Old 07-29-2012, 08:07 AM
tire joe's Avatar
Model: 1985 i
My bike does that once or twice a week, I wiggle the key and the light goes out . This has been going on over 5 years.
I want ride Tire Joe
tire joe is offline
post #8 of 15 (permalink) Old 07-29-2012, 05:14 PM
saltmar14's Avatar
Model: 2004 gl1800
if fuse ok, and bulbs ok check for shorts or it could be the tail light sensor.
i was about to replace my sensor as i was having intermittent proublems. i would have to turn key on and off a few times to get it to go off. when "on" the tail lights where not lit up. it was happening often thus the research, but then it stopped only happened once in the last 4-5 months.
my info comes from then Honda goldwing 1985 gl1200 electrical troubleshooting manual
current bikes
04 gl1800
85 limited edition
82 cm250c
previous bikes
early 80\'s 500 w/ add on fairing
xl 250 enduro (wish they made them like this still)
saltmar14 is offline
post #9 of 15 (permalink) Old 07-30-2012, 06:55 PM Thread Starter
asitis's Avatar
The tail lights are not affected in the least when the warning light comes on
asitis is offline
post #10 of 15 (permalink) Old 07-30-2012, 08:10 PM
saltmar14's Avatar
Model: 2004 gl1800
the brake and tail light sensor recieves an input that makes a ground for the indicator if the brake or taillight arent working, if they are there must be a short or signal going to the sensor. i'll keep seaching.
current bikes
04 gl1800
85 limited edition
82 cm250c
previous bikes
GL1200 Tail Light not working MarkAD Goldwing Technical Forum 5 07-31-2012 10:35 PM
GL1200LTD Instrument Panel and Tail Light Bulb Replacement BikerNewsman Goldwing Technical Forum 20 06-10-2012 09:22 PM
Stop light tail light led, GL1200 tb4511 Goldwing Technical Forum 7 05-23-2012 11:28 AM
Tail light short gl1200 What to do next? hillbilly1 Goldwing Technical Forum 12 08-16-2010 07:59 PM
1985 Aspy - Dash Tail Light Idiot light William_86 Goldwing Technical Forum 1 01-04-2010 09:35 PM
