GL1500 Antifreeze leaking slow at first now pouring - Steve Saunders Goldwing Forums
post #1 of 12 (permalink) Old 09-02-2012, 05:23 PM Thread Starter
Hi - I'm looking for help with a perplexing problem. I have a 1999 GL1500A that has an antifreeze leak. In search of origin I've taken off all the panels, fan, & cowling. I've inspected all hoses, radiator and isolated the overflow tank. Checked radiator cap ok, Problem presents only when thermostat kicks in, fans on. Findings-antifreeze seems to be gathering under the timing belt cover - removed cover. Appears antifreeze gathering in timing belt housing ? but still I cannot see where it is coming from ??. PS - engine purrs like a kitten, no sign of oil contamination. Any ideas or suggestions greatly apprecia
ted! Thanks Ed
echall777 is offline
post #2 of 12 (permalink) Old 09-02-2012, 05:32 PM
Zeke66's Avatar
Welcome to the forum Ed. If the water pump weep hole is dry, there are a few other possibilities for your leak. The metal crossover pipes on top of the engine are very thin and can leak, many posts about that from fellow forum members. Coolant tubes to the carburettors is another possibility.
Zeke66 is offline
post #3 of 12 (permalink) Old 09-02-2012, 05:49 PM Thread Starter
Thanks for the input. The weep hole is dry. Will check out suggestions and read prior forum on same. Appreciate it. By the way, I am formerly from Floral Park, LI, NY. Now in TX
post #4 of 12 (permalink) Old 09-02-2012, 05:51 PM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
Welcome to the forum echall777
Did you inspect the rubber on top of the Reservor tank where elbow is? That cracks and will spew antifreeze when hot.
Another spot is the crossover pipe between radiators.
Another I have seen is the bottom of reservoir tank locator **** worn through from wrong spaced holes in frame to hold it in place.
Let us know what you find.
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #5 of 12 (permalink) Old 09-02-2012, 06:11 PM Thread Starter
will do stu, been a long day,back at it in the am, M y main concern is where is it getting into the timing belt area
from the back ???.
ps north texas patriot guard, temp. grounded.
thx ed
post #6 of 12 (permalink) Old 09-02-2012, 06:19 PM
Still Learning
newday777's Avatar
Through the back of the timing belt cover? Not coming down from above there and leaking in?
Stu
Previous bikes
post #7 of 12 (permalink) Old 09-02-2012, 06:27 PM Thread Starter
not coming from above,best i can tell, comes from back and gathers on bottom shelf of inside timing belt housing
post #8 of 12 (permalink) Old 09-02-2012, 08:33 PM
groutby's Avatar
Model: '93 GL1500A...Black/Silver
Hi echall777 and welcome to the forum,...could it be coming from the water tubes at the rear of the thermostat housing?..worn "O" ring(s) or maybe the housing itself?..if so,I think your best bet would be to remove left radiator fan to get a better look.
Good luck,
Peter.
(was) WINGIN' "DOWN UNDER"....
1984 1200 Interstate....SOLD
1993 1500 Aspencade....SOLD
Will have again one day!
groutby is offline
post #9 of 12 (permalink) Old 09-02-2012, 11:48 PM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
I had exactly the same leak on mine... It's the large Y-shaped hose that attaches to the top of the thermostat. Look carefully at yours and verify that the hose is sitting flush to the 3(?) stops molded into the neck of the thermostat... If not, then the hose has lifted slightly off, resulting in a big leak whenever the thermostat turns on.
If yours is as such, then Remove the hose from the thermostat, and also remove any Clear Plastic Tape present on the thermostat connection (It is often very hard to see)... then re-assemble it. Verify it works by leaving one of the fans off the bike, then warming up the engine to the point where the thermostat opens... If the leak persists, then you'll easily see it emerge from that joint.
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #10 of 12 (permalink) Old 09-03-2012, 12:12 AM
John J's Avatar
Year: 2006
Make: Honda Goldwing
Model: GL1800A6
I remember reading on here somewhere that one of the bolts holding the timimg belt cover needs sealant as water can get past it. This leak sounds too big for that but maybe worth checking.
GL1800A 2006
Previously:
GL1500SE \'98
Harley Fatboy 2004
Triumph Rocket Touring 2010
Pan European ST1100
John J is offline
GL 1000 leaking antifreeze offcenter Goldwing Technical Forum 17 10-02-2012 09:44 AM
1982 1100 leaking antifreeze Broncoman Goldwing Technical Forum 13 07-31-2011 04:10 PM
Antifreeze leak GL1500 toy4rick Goldwing Technical Forum 19 02-20-2011 10:08 AM
GL1500 antifreeze Bluewings Goldwing Technical Forum 5 07-14-2010 07:05 AM
Changed Timing belts Now Antifreeze leaking Hawaii Goldwing Technical Forum 5 10-22-2008 07:31 PM
