GL1100. Do I really have an Overheating issue - Page 2 - Steve Saunders Goldwing Forums
post #11 of 19 (permalink) Old 10-20-2012, 10:42 AM
That wouldn't matter at any speed above 15mph or so. And the air scoops that goldtop mentioned are important, I tried it without them myself and although mine didn't overheat it did run hotter without them.
I realize that...well more like 30mph. But the original post was questioning if the bike was really getting hot or it was a gauge issue. If the fan runs normally at lower speeds but isn't on when 'pegging the needle' in OD, I might wonder if the problem was the gauge, sending unit or related wiring.
dizzy is offline
post #12 of 19 (permalink) Old 10-20-2012, 07:08 PM
I see your point but no way will he be able to hear the fan at that speed, 1100 fans barely make enough noise when stopped to hear it.
post #13 of 19 (permalink) Old 10-20-2012, 11:55 PM Thread Starter
Model: 1980 Semi std has a faring no bags with 83 powerplant
Put in a new Stant thermostat, also has a one year old stant radiator cap, to answer a few questions. And here is the story of what has happened so far.
Well, checked temps and stuff as suggested and everything seemed pretty close to normal seemed to be a gauge issue. I had around 75 miles on the replacement engine and since things looked good took the bike for a trip from VV to SD about 300 miles round trip. Engine ran great got to SD parked bike and next morning about a quarter since oil spot on the ground, not good but nothing to serious, I thought. As I went up the pass to VV the engine started to howl got to VV stopped for dinner and had a steady leak out of the weep hole about a sliver dollars worth before we could walk away from the bike. Had a nice dinner, drove the bike home the last few miles and the howl got worse and an nasty puddle under the weep hole after parking the bike at the house. So the next step is to Replace what sure appears to be a BAD water pump. Will update after replacement of the pump. By the way what is the trick to getting the o"rings on the pump to go in. When I did it on the old engine it was a real bear to get the pump fitted back in with the the o"rings on it.
Thanks for putting up with the story.
PTATSOC is offline
post #14 of 19 (permalink) Old 10-21-2012, 03:18 AM
Installing with dry o-rings seldom works. A little oil. grease or any other slippery substance makes installation easy and helps to prevent cutting the rings when installing.
Ken Bergen is offline
post #15 of 19 (permalink) Old 10-21-2012, 08:21 AM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
+1
I use Grease. Works on exhaust manifold gaskets too.
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #16 of 19 (permalink) Old 10-27-2012, 12:51 AM Thread Starter
Here's the update, the old water pump was wobbling so bad it was rubbing against the case good thing it was a fiber pump not a metal one. Also checked the thermostat I had it installed upside down. Used lot's of vasline on the o'rings put the pump in the freezer for about 4 hours and the pump slide in the case with a nice solid click with a good push. No leaks or drips in the driveway to late and cold to test drive tonight. Will give her a quick run in the morning before work.
Thanks for all the help
PTATSOC is offline
post #17 of 19 (permalink) Old 10-27-2012, 01:15 AM
To late I'll buy but to cold at 45F and no rain no way.
post #18 of 19 (permalink) Old 10-27-2012, 05:19 PM
overheating issue
Here is one of the lists available from NGW it has several of the parts you might try to bookmark it or copy and paste http://www.ngwclub.com/forum/viewtopic.php?f=24&t=7416
75 honda 750
83 honda shadow
79 GL1000 touring fitted (current)
gpif is offline
post #19 of 19 (permalink) Old 10-28-2012, 12:08 AM Thread Starter
Smile
It was to cold to find out if I had an overheating problem absolutely not to cold to drive, have to have snow on the ground before it is to cold.
PTATSOC is offline
GL1100 Overheating!! MEAN WNG Goldwing Technical Forum 28 06-30-2015 06:47 AM
GL1100 overheating backseat Goldwing Technical Forum 9 07-06-2012 05:14 PM
GL1100 OVERHEATING ROBERTONE Goldwing Technical Forum 12 05-28-2012 06:19 AM
overheating issue with radiator Gumpy Goldwing Technical Forum 22 04-16-2006 09:59 PM
Overheating issue still not solved in 79 sanfelice Goldwing Technical Forum 20 04-12-2005 10:25 PM
