R/R Audio Interference GL1100A - Steve Saunders Goldwing Forums
post #1 of 3 (permalink) Old 11-29-2012, 01:00 PM Thread Starter
fgh
Model: GL1100 Aspy
Hi,
Can the R/R cause audio interference? How could I test for it?
THANKS!!!
fgh
\'83 Aspy
\'83 GS750ES
fgh is offline
post #2 of 3 (permalink) Old 11-29-2012, 07:10 PM
choppas's Avatar
Most interference will probably be from the ignition. Have you tried suppressed plug caps?
Tom, GL1800
choppas is offline
post #3 of 3 (permalink) Old 11-30-2012, 11:49 AM Thread Starter
fgh
Model: GL1100 Aspy
Maybe! Thew caps were replaced in the last year with NGKs that are equipped with the 5K ohm resistor just like the OEMs. The interference doesn't seem to be in sync with the engine RPMs. It seems to be more present in the headset than the external speakers. I know there are like 10 diodes in the R/R that is probably the original and the headset leads run right past it. Thought that some maybe aged enough to cause EMI. I'm thinking I'll try it with the R/R disconnected to see what I get.
THANKS!!!
fgh
\'83 Aspy
\'83 GS750ES
fgh is offline
Audio interference from lighter plug....iPhone 4s odies Goldwing Technical Forum 1 03-12-2012 05:05 AM
Portable CB radio interference Q General Motorcycle Discussion Forum 6 01-02-2009 12:44 PM
Need help on audio I/C please...... kyboy67 General Motorcycle Discussion Forum 12 10-13-2008 08:27 PM
Radio Interference ChickenWing1200 Goldwing Technical Forum 0 06-17-2008 03:31 PM
Looking for 82 GL1100A audio schematics GSMacLean Goldwing Technical Forum 1 08-27-2006 03:09 PM
