97 1500 Aspy No Spark - Steve Saunders Goldwing Forums
post #1 of 34 (permalink) Old 02-10-2013, 12:25 PM Thread Starter
Senior Smart Aleck
erwjww's Avatar
Model: 97 GL1500 Aspencade
Changed timing belts yesterday. Wish I would have started bike before I began to make sure it's not a pre-existing condition but I don't think it is as it run fine when I put it away 2 months ago.
Here's my issue. While changing belts I had an issue with the pulse gen that sits in the middle of belt compartment. It was stuck and couldn't get it to swivel out of way to remove belt. It took alot of wiggling to get it to come loose and swivel. Now i have no spark at any plug. Bike did backfire real loud one time but most of time it won't do anything but spin. Backfiring to me means timing problem. Believe me I checked,rechecked, double checked, and then checked again, the timing marks before during and upon completion of job. Spun engine by hand several times also and marks always lined up perfectly using the T1-2 mark.
I have a multimeter but am not real up on the use of them.Going to do some research on this to try and make sure I know what I'm doing so I can check pulse gens.
I have done belts on other bikes before and never had any problems doing do. Any help in laymans terms would be greatly appreciated. THANKS
1984 Aspencade/24000 miles
1997 Aspencade/ 54500 miles
Life is a highway, I'm gonna ride it all night long,
God Willin and the Creek Don\'t Rise!!
Darksider #1409
Patriot Guard Rider
Honorary Rhino
GWRRA
Honorary Newfie!! I have kissed the Cod (or whatever it was), downed the Screech, and shouted "Long may your big jib draw", so I am now a member of the Royal Order of Newfoundland Screechers.
JACK WHITE
erwjww is offline
post #2 of 34 (permalink) Old 02-10-2013, 04:10 PM
Parman's Avatar
bump
Not much help other than to keep it up top so people see it.
Don (Parman)
"Sappers Lead the Way"
US Army (Retired)
101st Airborne Division (Ft Campbell KY)
1st Calvary Division (Ft Hood TX)
2nd Inf Division (Korea)
54th Engineer Bn (Germany)
Member of Patriot Guard Riders IL/WI
Honorary Wild Rhino
Honorary Newfie!! I have kissed the Cod (trout)downed the Screech, and shouted "Long may your big jib draw", so I am now a member of the Royal Order of Newfoundland Screechers.
95 1500 SE
Mileage: 103472
2010 GL1800
Mileage: 3604
Parman is offline
post #3 of 34 (permalink) Old 02-10-2013, 05:18 PM
First check that the kill switch is on, and that the cruise light comes on just to be sure it has power to the ignition. It may have nothing to do with the timing belt install. Even if the cams were out of time it would not effect ignition operation.
post #4 of 34 (permalink) Old 02-10-2013, 05:29 PM Thread Starter
Senior Smart Aleck
erwjww's Avatar
Yeh, I checked all that first Dave. Mine won"t crank with kill switch. Would the pulse gen cause my problem if i did hurt something wiggling it around. I used a meter on gens and got .490 on both.
Darksider #1409
Patriot Guard Rider
Honorary Rhino
GWRRA
JACK WHITE
erwjww is offline
post #5 of 34 (permalink) Old 02-10-2013, 05:43 PM
I keep forgetting the late 1500s won't crank with the kill switch off. Really an ohm reading is pretty meaningless on those, they can check fine and not work. They should put out a small AC voltage reading when cranking. Yes you could have damaged them if you got too rough.
post #6 of 34 (permalink) Old 02-10-2013, 06:10 PM Thread Starter
Senior Smart Aleck
erwjww's Avatar
The holes on those gens are recessed or kinda like a countersink. It acted and looked like it was corroded on as I had to work at it really hard with fingers to get it to pivot so I could remove belt. Had to get gently rough with it.
How do I check them for that small amount of voltage you are talking about. Manual just says unplug and take ohm reading.
Darksider #1409
Patriot Guard Rider
Honorary Rhino
GWRRA
JACK WHITE
erwjww is offline
post #7 of 34 (permalink) Old 02-10-2013, 06:18 PM
In the same way you checked the resistance, set the meter to the lowest AC voltage range and crank the engine.
post #8 of 34 (permalink) Old 02-10-2013, 06:23 PM
Busdriver
busdriver's Avatar
Year: 1990
Model: GL1500, 172,000 KM
Don't know which plugs are sparked by each pulse gen, maybe someone can chime in, but if the plugs which are controlled by the other pulse gen are firing, and those controlled by the p. gen you twisted aren't then yes I would suspect you damaged something.
busdriver is offline
post #9 of 34 (permalink) Old 02-10-2013, 06:23 PM Thread Starter
Senior Smart Aleck
erwjww's Avatar
Thanks I'll try that. Gonna have to get a helper or make me a couple alligator clip jumper wires. Thanks again Dave. I'll let ya know what I find out. Might be a couple days as work tends to get in the way.
You all healed up and back to 100%?
Darksider #1409
Patriot Guard Rider
Honorary Rhino
GWRRA
JACK WHITE
erwjww is offline
post #10 of 34 (permalink) Old 02-10-2013, 06:28 PM Thread Starter
Senior Smart Aleck
erwjww's Avatar
No fire at any plug. Pulled them all and layed them on head. Nothing. Was going to start bike with covers off to make sure belt tension was OK before I buttoned it up and this is where I'm at. I too thought it strange that no fire on any cylinder. Scratchin my head here.
Darksider #1409
Patriot Guard Rider
Honorary Rhino
GWRRA
JACK WHITE
erwjww is offline
difference in ride between Aspy 1200 and 1500 Aspy diver dean Goldwing Technical Forum 1 04-07-2012 11:46 AM
85 Aspy no spark jdvorchak Goldwing Technical Forum 12 02-19-2012 07:25 PM
GL 1500 Spark plugs subsailor Goldwing Technical Forum 5 06-05-2011 04:46 PM
85 Aspy spark plug wire question jdvorchak Goldwing Technical Forum 4 01-07-2011 08:40 PM
84 Aspy Spark plug wires Jerryk959 Goldwing Technical Forum 10 02-12-2009 08:43 AM
