1200 Front fork drain - Steve Saunders Goldwing Forums
post #1 of 15 (permalink) Old 03-21-2013, 06:32 AM Thread Starter
pepmyster's Avatar
Model: 2001 Valkyrie Interstate
Hi Guys!!! Screw it, I have to ask, where is the front fork drain screw (plug) on my 85 Aspy? I want to drain and replace the front fork oil. Thanks!
I have been living...I just didn't realize it.......
pepmyster is offline
post #2 of 15 (permalink) Old 03-21-2013, 07:58 AM Thread Starter
pepmyster's Avatar
Sorry, A little more checking and I found it, started to drain the oil. Man, it was due. I removed the top cap, and as many have said, was careful. Cap did pop off, now to replace the oil and try to put the cap back on!!!
post #3 of 15 (permalink) Old 03-21-2013, 08:53 AM Thread Starter
pepmyster's Avatar
Left fork had the proper amount, but black. Right fork had about 100ml in it if that. Wow.
post #4 of 15 (permalink) Old 03-21-2013, 08:55 AM
Large Member
wilmo's Avatar
where is the fork drain bolt? Mine need to be done as well...
Wilmo
Rubber side down!
101421 miles as of 091418
wilmo is offline
post #5 of 15 (permalink) Old 03-21-2013, 10:04 AM Thread Starter
pepmyster's Avatar
It's the bolt between the arrows of the anti dive case and the arrow of the boot
post #6 of 15 (permalink) Old 03-21-2013, 10:06 AM Thread Starter
pepmyster's Avatar
The top cap bolt, be careful. Mine "popped" off. There is pressure there caused by the top spring. Please keep this in mind and protect yourself. Hell, if I can do it.......
post #7 of 15 (permalink) Old 03-21-2013, 10:22 AM
Large Member
wilmo's Avatar
Thank you for that info. Now for the $64 question, how do you refill it? If I've read right on other posts, you have to inject it into that same hole...? Sounds quite difficult to fill it that way, how would you keep it in there while attempting to quickly put that plug back in against spring tension? Gotta be a trick... I will assume that I would also have to release all the air in the front shocks as well before draining/filling. What do you mean by top cap bolt or is the drain what you're talking about?
Wilmo
Rubber side down!
wilmo is offline
post #8 of 15 (permalink) Old 03-21-2013, 10:36 AM Thread Starter
pepmyster's Avatar
I poured the oil in from the top cap.
post #9 of 15 (permalink) Old 03-21-2013, 11:09 AM
Large Member
wilmo's Avatar
OK that's my stupid question, what is the top cap? never done forks before so I'm in learn mode
Wilmo
Rubber side down!
wilmo is offline
post #10 of 15 (permalink) Old 03-21-2013, 11:14 AM Thread Starter
pepmyster's Avatar
The cap on top of the shocks. Be careful!
1200 ltd front fork bumblebee Goldwing Technical Forum 2 12-30-2011 01:33 PM
1994 GL1500SE Front fork oil drain bolt Jim_C Goldwing Technical Forum 11 10-06-2011 06:31 PM
1983 GL Fork Oil Drain? Oldbro Goldwing Technical Forum 5 09-08-2009 10:41 PM
Front fork drain plug on 83 GL1100 shawzy Goldwing Technical Forum 3 08-19-2009 03:05 PM
GL 1200 Front Fork Seals??? mespock Goldwing Technical Forum 6 05-01-2007 12:17 AM
