Removing a rounded out hex bolt (on GL1800 footpegs) - Page 2 - Steve Saunders Goldwing Forums
post #11 of 11 (permalink) Old 04-29-2013, 07:43 PM
Just an FYI on screws in aluminum. Impact is the key, i.e. put the allen socket, screwdriver, torx bit or whatever in the screw head head and strike it sharply with a hammer a few times and they will normally screw out with no effort at all.
Rounded oil filter bolt, GL1100 George 56-81 Goldwing Technical Forum 7 04-06-2013 05:47 PM
Large silver hex bolt/plug behind oil filter, GL1800 grm3 Goldwing Technical Forum 9 09-27-2009 03:01 AM
Large silver hex bolt/plug behind the oil filter, GL1800 grm3 Goldwing Technical Forum 1 09-26-2009 01:22 PM
help to remove rounded allen bolt pinkpork Goldwing Technical Forum 11 08-13-2007 06:39 PM
Hex Bolt Caps: teacher General Motorcycle Discussion Forum 2 04-23-2006 08:22 AM
