New GL1200 fork seals leaking!!!!? - Page 2 - Steve Saunders Goldwing Forums
post #11 of 13 (permalink) Old 05-25-2013, 01:17 AM
Generally a seal is installed with the spring side facing pressure which would be downward in a Goldwing fork and the tiny diagram in the Honda manual would seem to support this.
Ken Bergen is offline
post #12 of 13 (permalink) Old 05-25-2013, 06:27 AM
Mr Magic Fingers's Avatar
Hey Flounder,
Please check out the following link. It was a thread that I posted to with some good close up pictures of parts orientation for the GL1100 and shows the proper orientation of the seal. Not much difference with the GL1200.
https://www.goldwingfacts.com/forums/...-bushings.html
Hope it helps…
Tim.
____
Please visit
Mr Magic Fingers is offline
post #13 of 13 (permalink) Old 08-26-2013, 11:29 AM
Senior Guru
Goldwinger1984's Avatar
Originally Posted by busdriver View Post
Yes the seals have a top and bottom. They must be installed the right way up.
And yes you overfilled the fluid. Common mistake.
I have always installed seals by placing the name and numbers on the up side and it has always worked out for me.
Goldwinger1984 is offline
leaking fork seals triumph fan Goldwing Technical Forum 3 01-18-2008 04:11 AM
Leaking fork seals longhaireddwb Goldwing Technical Forum 3 07-06-2007 06:18 AM
Fork seals leaking..still trnpkcruzr Goldwing Technical Forum 7 07-05-2006 12:28 PM
leaking fork seals n2xwv Goldwing Technical Forum 1 05-13-2006 10:47 PM
leaking fork seals n2xwv Goldwing Technical Forum 3 05-13-2006 09:30 PM
