GL1500 LCD off - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 05-29-2013, 01:35 PM Thread Starter
GL1500 LCD off
Hello
I have an issue since many years with my 1997 1500. In moisty days (humid?) my LCD stay off for a while (about 10-15 minutes) after I start riding. When it lits up some lights of the dashboard come on (fuel, cruise on,cruise set for sure). I discovered when the LCD is off the air panel doesn't work too.... I already swapped some relais but without solve.
Have you any idea?
Thanks
Andrea
andrew59it is offline
post #2 of 4 (permalink) Old 05-29-2013, 02:02 PM
It aint rocket science
DriverRider's Avatar
Model: The best
Some good threads here to research.
https://www.goldwingfacts.com/forums/...d-display.html
J.D.
Internet myth buster
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
DriverRider is online now
post #3 of 4 (permalink) Old 05-29-2013, 02:39 PM
wingpilot96's Avatar
Model: 08 1800HPNA
Originally Posted by andrew59it View Post
Hello
Have you any idea?
Thanks
Andrea
It is an issue with my 96 SE also..it is a humidity issue. You could try to remove the unit, clearn the module ckt board, look for possible cold solder joints, resolder then coat with a waterproofing spray. but the big issue is getting the module out of the assembly...it take a lot to get to it. However, if you are in ther it is a good time to replace light bulbs with LED's
2008 GL1800 HPNA - 18,500+ miles
1988 Bunkhouse Camper
wingpilot96 is offline
post #4 of 4 (permalink) Old 05-30-2013, 10:43 AM Thread Starter
Thank you....
I already got it out 2 or 3 times.... yes I already bought the LED lamps and they are waiting. I cleaned the board without coating it with clear paint one time. Next time I will try to seal it....
gl1500 lcd screen steve worth Goldwing Technical Forum 27 12-06-2015 09:41 PM
GL1500 LCD Display SA Goldie Goldwing Technical Forum 7 02-25-2013 06:42 AM
GL1500 LCD Interchangeability lopeha Goldwing Technical Forum 5 01-27-2013 09:14 AM
GL1500 SE LCD on dash..... daveinozbikes Goldwing Technical Forum 1 05-10-2012 02:57 AM
Need LCD for a GL1500 ifly1956 For Sale/Wanted Forum 6 01-04-2012 06:22 PM
