Starting Problem - GL1200 Aspencade - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 09-24-2013, 10:50 PM Thread Starter
Year: 1987
Make: Honda Goldwing
Model: GL1200 Aspencade
Question Starting Problem - GL1200 Aspencade
My 1987 Aspencade suddenly gave up on the road the other day when I was taking it for its first ride of the season after a few months in the shed - the engine just cut out suddenly. It started again after about 15 mins, but cut out a few more times before I got it home. I took out a plug and checked the spark - it sparked and the bike started. Then I switched it off and tried to start it again - no go and no spark when I checked the plug. For the last few rides, the air compressor has worked intermittently and so have the tail lights. Are these problems likely to be connected or are they separate issues? All advice gratefully received before I start to take it apart!
Andrew T is offline
post #2 of 6 (permalink) Old 09-24-2013, 11:19 PM
Born in the USSR
Sergey's Avatar
Year: 1986
Model: 1986 GL1200 Aspencade
Send a message via Skype™ to Sergey
Hi,
Would think it's a kind of problem with kill switch.
Regards,
Sergey
1986 Honda GL1200A Gold Wing
1993 Suzuki GSX400SSN Katana
and...4 cats
My GL1200:
Single Solex carb conversion kit:
Sergey is offline
post #3 of 6 (permalink) Old 09-24-2013, 11:27 PM Thread Starter
Year: 1987
Originally Posted by Sergey View Post
Hi,
Regards,
Sergey
Thanks Sergey - will check it out
Andrew T is offline
post #4 of 6 (permalink) Old 09-24-2013, 11:28 PM
glhonda's Avatar
Hi,
Sergey
More likely the ignition switch. Try wiggling the key during the event.
PG's are always suspect, but it's quite a coincidence you're losing power in other areas as well.
glhonda is offline
post #5 of 6 (permalink) Old 09-25-2013, 06:30 AM Thread Starter
Year: 1987
Thanks - it started again today after being moved in the shed, then stopped, so a switch issue sounds logical. I'll have a good look at the switches and hopefully find something loose.
Cheers, Andrew
Andrew T is offline
post #6 of 6 (permalink) Old 11-03-2013, 05:39 AM Thread Starter
Year: 1987
Problem found
Think I found the problem today. Removed the seat and top compartment and found the large connector coming from the fuse box was slightly loose. Plugged it in properly and everything works again - bike started, rear lights on and air compressor going again. Thanks everyone for your suggestions. Cheers, Andrew
Andrew T is offline
Starting problem'84 GL1200 Aspencade nalambert Goldwing Technical Forum 11 05-13-2013 04:46 PM
'86 GL1200 Starting Problem OriginalPaladin Goldwing Technical Forum 13 06-11-2011 09:38 PM
84 gl1200 starting problem OzzFreak Goldwing Technical Forum 6 03-12-2011 05:53 AM
1985 Aspencade starting problem ThWall Goldwing Technical Forum 3 06-14-2008 11:00 AM
1986 Aspencade Starting Problem piper451 Goldwing Technical Forum 9 04-12-2005 12:50 AM
