87 gl 1200i finial drive installation - Steve Saunders Goldwing Forums
post #1 of 17 (permalink) Old 10-13-2013, 08:34 PM Thread Starter
Ronscycle1's Avatar
Model: 1987 gl 1200 I
can i just slide the axle though the swnig arm without putting on rear wheel to align the finial drive to swing arm ?
Ronscycle1 is offline
post #2 of 17 (permalink) Old 10-13-2013, 08:53 PM
Well sort of, you could do that and leave the nuts slightly loose than tighten them after you put the wheel in.
post #3 of 17 (permalink) Old 10-13-2013, 09:16 PM
First, welcome to the forum.
What Dave says is correct, but I'd like to know what you wish to accomplish. Why do you want to align the drive at this point?
post #4 of 17 (permalink) Old 10-13-2013, 11:48 PM Thread Starter
Ronscycle1's Avatar
installing new finial drive
post #5 of 17 (permalink) Old 10-14-2013, 12:01 AM
Honda Guru
rayworx's Avatar
Year: 1988
Make: Honda GoldWing
Model: 88 GL1500
Your going to have to put the rear wheel on…. at some point in time. Leave the nuts that attach the final drive to the swing arm loose. Install the wheel, put the axle through (make sure all the spacers, brake caliper and washers are in place) then snug up the axle nut. You don't need to torque it to specs, just get it tight. Tighten up the 'pinch bolt' on the opposite side and then tighten the final drive nuts. Now you'll be sure it's straight and aligned.
Ray
88 GL1500
rayworx is offline
post #6 of 17 (permalink) Old 10-14-2013, 01:53 AM
Ron Wylie's Avatar
Model: 1993 GL1500SE(P)
Final Drive
Installing a "new" final drive on my GL1500SE, so do I leave the nuts slightly loose on mine, in the same way ?
1993 GL1500SE 114,000 and Rising
North East Lincolnshire, UK
Ron Wylie is offline
post #7 of 17 (permalink) Old 10-14-2013, 08:15 AM
Bellboy40's Avatar
Year: 2000 & 1994
Ron, the rear drive installation on the 1500 would be like what was described for the 1200. You tighten up the final drive nuts last.
Larry
-- Albert Einstein
Bellboy40 is offline
post #8 of 17 (permalink) Old 10-19-2013, 03:28 AM
Ron Wylie's Avatar
Final Gear Alignment
Got the Final gear back on the swingarm but how loose do the nuts want to be ? Do they want to be finger tight or with a gap between the arm and the drive unit ? (ie do I tighten the nuts so the Final Drive unit touches the swingarm) l
Thanks very much.
post #9 of 17 (permalink) Old 10-19-2013, 07:35 AM
Yeah, almost finger tight is fine. Just enough so it can move freely to align itself when the axle tightens.
post #10 of 17 (permalink) Old 10-20-2013, 12:49 AM Thread Starter
Ronscycle1's Avatar
Got finial drive on but with the bike on side stand if i lean it back and forth it kinda makes a lil popping noise what could this be ? Could it be slack in the finial drive and flange ?
GL1200i Final drive and drive shaft installation WB8BIL Goldwing Technical Forum 13 10-23-2013 07:26 PM
GL1500 final drive and drive shaft removal tutorial uploaded wingnut Goldwing Technical Forum 15 09-22-2011 04:52 AM
1981 GL1100 final drive & wheel removal and installation 81GWGL1100 Goldwing Technical Forum 4 05-19-2010 10:14 PM
What is this? (84 1200I) escogold Goldwing Technical Forum 9 08-06-2009 12:30 AM
Want Final Drive and Drive Flange/Rear wheel for 88/89 GL1500 4evermetric For Sale/Wanted Forum 0 09-20-2007 04:58 PM
