1998 1500 Drive line vibration, I think - Steve Saunders Goldwing Forums
post #1 of 13 (permalink) Old 10-19-2013, 10:47 PM Thread Starter
The Fonz's Avatar
Model: 1998 1500 SE
Guys,
Looking for some help to diagnose a strange vibration. At about 2100-2200 RPMs in any gear and sometimes when up shifting I get kind of a buzzing vibration. It kind of feels like there is a large bee in the middle of the bike. If I drop below 2100 RPMs, go above 2200 RPMs, or pull the clutch in the vibration goes away. It is not in the pegs and feels like it is more in the bottom of the seat. It is light but annoying.
I pulled the entire drive line today and could not find anything out of the ordinary. The U-joint looks good (I replaced it about 20,000 miles ago). The splines were not dry.
The only thing I saw that struck me as odd was that I had what looked like brake dust on inner rim of the side of the wheel that faces the final drive.
Any ideas? I don't think it is the alternator dampeners as it goes away if you pull the clutch in.
Thanks,
Ed
If it\'s got two wheels, I\'m in trouble.
The Fonz
IBA 42427
Our Alaska Trip:
The Fonz is offline
post #2 of 13 (permalink) Old 10-19-2013, 11:30 PM
Still IMO the alternator dampers are exactly the first thing to replace "just for drill".
The rubber becomes hardened and non-resilient.
post #3 of 13 (permalink) Old 10-20-2013, 06:04 AM
The Irish Crew
Heffo's Avatar
Have a closer look at the UJ. Twist and pull it for signs of play or roughness.
Dave Heffernan.
Heffo is offline
post #4 of 13 (permalink) Old 10-20-2013, 06:16 AM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
Like John said replace the alternator drive dampener rubbers.
Have you been lubricating all the drive splines yearly? From the motor output shaft, drive shaft, to the rear wheel?
If the dust you referred to is red it is lack of moly paste on the drive splines but your words didn't make clear if the brake dust on inner rim was inside the drive hub or not or color. Black would be brake dust.
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #5 of 13 (permalink) Old 10-20-2013, 06:42 AM
Year: 1995
Model: '95 GL1500SE/CSC Friendship III
Just a thought....carb synchronization? Another fellow had small vibration from his alternator. He simply pulled unit back enough to CHANGE POSTITON of drive impeller in rubber blocks....vibration disappeared. ....papasmurf
Old Tom aka papasmurf in NH
'95 GL SE/CSC Friendship III sidecar ng
Member: NE3Wheelers Sidecar Club of MA
USAF jet aircraft mechanic in Cold War era
HO Scale model railroader
John Wayne film collection
LOVE The Beatles!
papasmurf is offline
post #6 of 13 (permalink) Old 10-20-2013, 09:46 AM Thread Starter
The Fonz's Avatar
Model: 1998 1500 SE
I pulled the UJ yesterday, no signs of play or roughness. It was in good shape. I replaced it in July of last year (18,000 miles ago).
All of the splines are lubricated with Molly often, from the output shaft to the rear wheel. This was last done when I did the UJ in July last year. The dust was black and was on the wheel rim where the large rubber boot from the final drive meets the wheel rim. I don't seem to recall seeing that much dust there in the past, but then again, most of my miles since then have been loaded down pulling a Bunkhouse that we had.
Just asking, if it were a carb sync issue, wouldn't I get the buzz when the bike is in neutral and I took the motor to the RPM range where I am experiencing the buzz?
The rubber dampers seem to be the common theme here. I replaced them October 16th of 2010 (36,000 miles ago) when I put a HO alternator in from Ken Hemming. I later replaced the HO alternator with a Compufire in April of 2012 (27,000 miles ago) but did not replace the dampers at that time.
I will replace them, then report back. Thank you for the help guys.
Ed
The Fonz
IBA 42427
Our Alaska Trip:
The Fonz is offline
post #7 of 13 (permalink) Old 10-20-2013, 09:53 AM
Still Learning
newday777's Avatar
The dampeners get oil on them and that causes them to harden and yes 3 years they can be hard.
Stu
Previous bikes
post #8 of 13 (permalink) Old 10-20-2013, 11:12 AM Thread Starter
The Fonz's Avatar
Model: 1998 1500 SE
I ordered the new dampers this morning.
The Fonz
IBA 42427
Our Alaska Trip:
The Fonz is offline
post #9 of 13 (permalink) Old 10-20-2013, 12:02 PM
Ah, a good thing IMO.
When that Compufire alternator went in, for me, it would have had new dampeners with it. The cost is neglible.
But, you have the fix "IMO" ordered so it won't matter. Apparently you and the bike are on a one-to-one relationship and maintenance is great in your hands.
post #10 of 13 (permalink) Old 10-20-2013, 08:40 PM
If it vibrates at a certain RPM regardless of speed it is not the drive line. The shaft turns a 2.83 times wheel speed regardless of engine RPM or gear position. If you have a vibration at X RPM it is engine related, If the vibration is at X speed, no matter what gear or RPM then it is drive line or wheel related.
93 1500 Aspencade Drive line removal and lubing Sauceman Goldwing Technical Forum 43 11-11-2014 02:32 PM
Drive Line McFirefighter Goldwing Technical Forum 2 06-02-2009 03:37 PM
1998 Goldwing Aspencade vibration glassworks01 Goldwing Technical Forum 5 09-10-2008 10:19 PM
1988 GL 1500 vibration in drive line??? 211Chuck Goldwing Technical Forum 30 08-16-2008 08:48 PM
GL1800 drive train vibration DRElrod Goldwing Technical Forum 6 03-25-2008 07:11 PM
