GL 1200- How long for normal warm up? - Steve Saunders Goldwing Forums
post #1 of 19 (permalink) Old 10-30-2013, 06:53 AM Thread Starter
Model: 1986 GL 1200A
Still "sorting out" my resurrected 1200. How long does the choke need to be on this bike, it seems a lot longer than my other Hondas. It seems to take 3-4 miles of driving before I can take the choke completely off, otherwise it bogs slightly and I get a lean popping in the airbox, once warmed however it's fine. It's still lean for a bit even if my water temp indicates 3 bars on the gauge, another mile or so then it is fine. Outside temp was about 50 degrees when i left for work this AM.
My gut feeling is I should have drilled the blocks ever the idle mixture screws and backed them out a bit. Hindsight is 20-20! as I recall 80's Hondas are lean off idle, on my CBX I shimmed my needles 1.5 mm and backed out the idle mixtures to 2.5 turns, and it has run faultless for years. Even though it is air cooled, I can run without choke in 1/4 mile.
RATWING-86 is offline
post #2 of 19 (permalink) Old 10-30-2013, 08:29 AM
WingMan71's Avatar
Year: 2006
Model: GL1800, GL1200, GL1000
Both my '84 Interstate and my current '87 Aspencade have been that way.
Very cold-blooded. Like you say, a good 4 or 5 miles of riding before the choke can come completely off.
I'll be interested in what other GL1200 owners say.
Bob
2006 Arctic White GL1800
1987 Black/Grey GL1200 Aspencade
1976 Special Candy Maroon GL1000 LTD
U.S. Navy SWO (1967-1976)
WingMan71 is offline
post #3 of 19 (permalink) Old 10-30-2013, 09:26 AM
Do an idle drop and see if that helps.
Mine has never really been that cold blooded.
post #4 of 19 (permalink) Old 10-30-2013, 11:38 AM
tfwarner23's Avatar
Year: 2001
Make: Harley Davidson
Model: ULTRA CLASSIC ELECTRA GLIDE - EFI
Send a message via Skype™ to tfwarner23
i live in ND, my 1200 and now my 1500 takes about 2 minutes and half a mile before i take the choke off, no ethanol in the gas, premium only
Thomas
OPMC - Our Place Motorcycle Club
ABATE of ND - Board of Director
"Lets Ride Together"
GWRRA - Capital Wing Riders, Chapter C
2001 HARLEY DAVIDSON ULTRA CLASSIC ELECTRA GLIDE - EFI
1995 GL1500SE
Previous Owned
1984 GL1200I
1979 Yamaha 650 Special II
1981 Yamaha XV920R
1984 Suzuki GS1100GKE
tfwarner23 is offline
post #5 of 19 (permalink) Old 10-30-2013, 09:58 PM
oldishwinger's Avatar
yep very cold blooded they are, I have routine, that helps, I carry my helmet, gloves, top coat out the bike, and place them handy. start the bike with about 3/4 choke, then bring it back until its idling on the choke, at about 12-1300 rpm.
put gear on, and by the time I pull out, it showing one temp bar, and I can turn the choke right off.
she still feels a bit grunty, but once 3 bars are up it all good.
Robbie,
1986 Gl1200 Aspencade (Mariah)
\'I ride not to get there, but to go\'
oldishwinger is offline
post #6 of 19 (permalink) Old 10-31-2013, 06:57 AM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
Mine needs the choke for about 2-4 min depending on how cold it is. I have a 1/4 mile driveway and always have the choke off by the time I get to the road. Yesterday, I started my bike and let it idle about 3 min before the choke was ready to shut off. I wasn't quite ready but my battery was low and I didn't want to shut it off. I have great throttle response except when I shut the choke off to soon.
JeffMayfield is offline
post #7 of 19 (permalink) Old 10-31-2013, 11:26 AM Thread Starter
Dennis, by "idle drop" are you referring to a idle fuel mixture adjustment, or just a curb idle drop, right now I'm perfectly synced and idling nicely at 1000 rpm +_ 20
And yes it pops in the air box easily 3-4 miles and a bit even when at 3 bars temp, a few MORE miles and then it stops.
I heard that 86-87 wings have even LEANER idle mixture settings than 84-85 Wings, true?
post #8 of 19 (permalink) Old 10-31-2013, 12:58 PM
Born in the USSR
Sergey's Avatar
Year: 1986
Model: 1986 GL1200 Aspencade
Send a message via Skype™ to Sergey
I start the bike with full choke on and make it 1/2 in 10-30 seconds (1700-2000 rpm). After that I smoke my morning cigarette, make the choke off and ride I never ride with a choke on. It's a magic morning procedure (starting, smoking, listening to ZZ Top). No hurry, no rush It's a Gold Wing!
1986 Honda GL1200A Gold Wing
1993 Suzuki GSX400SSN Katana
and...4 cats
My GL1200:
Single Solex carb conversion kit:
Sergey is offline
post #9 of 19 (permalink) Old 10-31-2013, 02:03 PM
killer driller
jon jay's Avatar
Model: 1999 1500se,1986 gl1200
As far as I know even premium has ethanol in it unless otherwise posted
"ride safe my friends"
jon jay is offline
post #10 of 19 (permalink) Old 10-31-2013, 07:56 PM
Just Winging It
Year: 1986
Make: GL1200I
Model: GL1200I 1986
This is from the 1200 Honda service manual. You will likely need a sensitive tachometer hooked up to measure accurately enough to perform this procedure. Once it's done, it doesn't tend to go out - you won't need to repeat it.
IDLE DROP PROCEDURE
NOTE: Use a tachometer with graduations of 50 rpm or smaller that will accurately indicate a 50 rpm change.
1. Turn each pilot screw clockwise until it seats lightly and back it out to the specification given. This an initial setting prior to the final pilot screw adjustment.
INITIAL OPENING: 3-1/2 turns out
CAUTION: Damage to the pilot screw seat will occur if the pilot screw is tightened against the seat.
2. Warm up the engine to operating temperature. Stop and go driving for 10 minutes is sufficient.
3. Attach a tachometer according to the manufacturer's instructions.
4. Adjust the idle speed with the throttle stop screw.
5. Turn each pilot screw 1/2 turn out from the initial setting.
6. If the engine speed increases by 50 rpm or more, turn each pilot screw out by a continual 1/2 turn until engine speed drops by 50 rpm or less.
7. Adjust the idle speed with the throttle stop screw.
8. Turn the No.1 carburetor pilot screw in until the engine speed drops 50 rpm.
9. Turn the No.1 carburetor pilot screw 1 turn out from the position obtained in step 8.
10. Adjust the idle speed with the throttle stop screw.
11. Perform steps 8, 9 and 10 for the No.2. No.3 and No.4 carburetor pilot screws.
http://goldwingdocs.com/forum/viewtopic.php?f=5&t=3687
GL1100 - A long time to warm up?? WishboneTull Goldwing Technical Forum 13 05-30-2010 10:54 AM
How long warm up? MoneyGuy General Motorcycle Discussion Forum 18 06-27-2009 04:05 AM
How long to warm an 1100 up? Bullfrog Goldwing Technical Forum 14 03-26-2009 04:45 PM
How long do you have to ride until new spark plug gets normal color? newbiker Goldwing Technical Forum 1 11-08-2007 12:37 PM
How long the tire able to keep in normal room ? 4 Year surapong Goldwing Technical Forum 2 06-15-2007 02:19 PM
