83' GL1100 Head gasket, Oil light 2nd gear jerking - Steve Saunders Goldwing Forums
post #1 of 13 (permalink) Old 11-01-2013, 10:27 PM Thread Starter
MarkV's Avatar
Model: 1983 Aspencade
Hello,
Is there anyway replacing the left head gasket would have effected the Oil light staying on after about 2 miles ( yes oil level is perfect) , Also 2nd gear wont stay engaged now, meaning, it jerks in and out of gear. all other gears are seemingly working as they should. Did not have these issues before the head gasket ..
Thank You
MarkV is offline
post #2 of 13 (permalink) Old 11-01-2013, 10:34 PM
It aint rocket science
DriverRider's Avatar
Model: The best
Did the oil orifice get put back in?
J.D.
Internet myth buster
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
DriverRider is online now
post #3 of 13 (permalink) Old 11-02-2013, 12:39 AM Thread Starter
MarkV's Avatar
You mean the little round tube with the O ring, goes in the top middle of block\head ?
if so, Yes it did
MarkV is offline
post #4 of 13 (permalink) Old 11-02-2013, 07:05 AM
Should not have affected either, could be some small piece of gasket or something was the last little bit needed to plug up the oil screen. If you had to remove you heel/toe shifter mechanism to do the job maybe it didn't go back on exactly as it was and is hitting something.
post #5 of 13 (permalink) Old 11-02-2013, 08:04 AM Thread Starter
MarkV's Avatar
I will check out the screen, Does anyone know , if there is an oil flow issue, Will it cause 2nd gear to pop in and out ?
MarkV is offline
post #6 of 13 (permalink) Old 11-02-2013, 02:05 PM
tire joe's Avatar
Model: 1985 i
If the shifter is not adjusted correctly to go into 2nd all the way it could pop out. I would check the oil pressure with a gauge.
I want ride Tire Joe
tire joe is offline
post #7 of 13 (permalink) Old 11-02-2013, 06:05 PM
No, the transmission oil is not pressurized, it just oils from the sump.
post #8 of 13 (permalink) Old 11-02-2013, 06:14 PM Thread Starter
MarkV's Avatar
I figured it was not under any pressure, I was more wondering, If there is an oil flow issue, would that be somehow related to the 2nd popping in and out of gear, Its just seems odd that , before I replaced the head gasket and new oil filter all was running fine, Put new head gasket in and I am having oil pressure issue and 2nd gear issues.
MarkV is offline
post #9 of 13 (permalink) Old 11-02-2013, 06:46 PM
No, as i stated before, If there is oil in the sump the transmission is in oil.
post #10 of 13 (permalink) Old 11-02-2013, 09:40 PM
ErnieB's Avatar
Model: 87 1200i
Remove the shifter, noting its location, and move it higher by ONE notch. Been there done that.
Never Too Old To Ride
ErnieB is offline
Best aftermarket gasket kit for GL1100 head gasket job? Tom2 Goldwing Technical Forum 4 07-06-2010 01:20 PM
gl1200 ltd Oil leak from head gasket brendan2208 Goldwing Technical Forum 6 04-17-2010 01:21 PM
anyone ever loose 2nd gear gl1100 JBz Goldwing Technical Forum 6 11-10-2009 09:12 PM
Neutral Light Is between 2nd Gear and 4th now? creationworks Goldwing Technical Forum 9 05-26-2009 08:43 AM
GL1100 Oil/Coolant mixing- head gasket? DaveTV Goldwing Technical Forum 15 06-25-2007 05:09 PM
