GL1500 smoking when cold - Steve Saunders Goldwing Forums
post #1 of 13 (permalink) Old 11-03-2013, 01:55 PM Thread Starter
Model: 1500 gl
hi there. i have a 1990 gl 1500 with 46 k on clock.
when starting the bike from cold with say three quater choke i get smoking with that burning oil smell, for say around a minute, untill she warms up. the bike isnt burning any oil, wondered if anyone else has this any info would be gladly recieved thank you darren
fodenbiking is offline
post #2 of 13 (permalink) Old 11-03-2013, 02:10 PM
Unofficial Youtube Addict
Happytrails's Avatar
Model: 1991 Goldwing SE Anniversary Edition
I was worried about the same thing when I saw blue smoke coming from the left side on a cold startup. I did some searchin and it turns out this is normal, particularly if you had your bike on the side stand. A little oil seeps into the cylinder. If you use the center stand it will help with this according to what I've read about it.
Happytrails is offline
post #3 of 13 (permalink) Old 11-03-2013, 03:37 PM
John J's Avatar
Year: 2006
Make: Honda Goldwing
Model: GL1800A6
Very common on 1500's and nothing to worry about.
GL1800A 2006
Previously:
GL1500SE \'98
Harley Fatboy 2004
Triumph Rocket Touring 2010
Pan European ST1100
John J is offline
post #4 of 13 (permalink) Old 11-03-2013, 03:55 PM
Model: 89 Goldwing
Same with mine. Sometimes worse than others and sometimes not at all. Now I don't pay it much attention.
reh1966 is offline
post #5 of 13 (permalink) Old 11-03-2013, 04:39 PM
Year: 2008
My 93 SE was the same. It stopped when I started using the CT, and I still use the CT on my 1800. I only use the side stand for temporary stops and always use the CT for overnight on trips and in the garage.
Charlie
flylow is offline
post #6 of 13 (permalink) Old 11-03-2013, 06:56 PM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
If you have too much oil in it, it'll smoke. Check oil on center stand, remove dipstick and wipe dry, put back in but only set on threads to get proper level read. Top line in the middle of the flat area is the high mark.
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #7 of 13 (permalink) Old 11-04-2013, 11:48 AM
KEVLAFLEUR's Avatar
Model: GL1500 SE
The smoking on my bike seems directly related to how far I open the choke. I start it with a small amount of choke and open it up as needed to run right. I know it doesn't seem like a choke issue, but if I work the choke that way, no smoke at all.
Even a bad day riding is better than work.
KEVLAFLEUR is offline
post #8 of 13 (permalink) Old 11-04-2013, 11:53 AM Thread Starter
Model: 1500 gl
thank you everyone who replied im more settled about this now thanks again,
post #9 of 13 (permalink) Old 11-04-2013, 11:55 AM
Still Learning
newday777's Avatar
It could be. It could be in that case float levels also.
The choke on the 1500 is actually called an enrichment valve and it may be putting too much gas in and need resetting per the repair manual.
Stu
Previous bikes
post #10 of 13 (permalink) Old 11-04-2013, 11:58 AM
Still Learning
newday777's Avatar
Be sure you post a reply to this thread what you find the cause is to help others later that read it using the search tool and to close the thread original post question.
Stu
Previous bikes
GL1500 smoking huey Goldwing Technical Forum 13 12-02-2012 02:53 PM
GL1500 smoking on startup shinner29 Goldwing Technical Forum 12 06-22-2011 07:19 AM
GL1500 smoking like a train rustyrider Goldwing Technical Forum 13 08-20-2010 07:18 AM
white smoking on cold start colombian.husker Goldwing Technical Forum 5 05-11-2009 09:46 PM
GL1200 I 87 Engine smoking when started in cold weather exrich Goldwing Technical Forum 12 01-31-2008 07:40 AM
