GL1000 won't start. blocks up, help!!! - Steve Saunders Goldwing Forums
post #1 of 7 (permalink) Old 04-19-2014, 01:04 PM Thread Starter
Model: 75 gl1000
Question GL1000 won't start. blocks up, help!!!
Alright guys, so my dad was neglectful. I have almost no "real" mechanical knowledge. And I jumped in waaaaay over my head with a 75 1000 I got for the prjce of tires basically.
Problem is, it doesnt start.
I think ive got it narrowed down to spark finally, after tearing it down to the frame. Brand new battery, clean and vaccuim gauge set carbs, new lines, 3.7 liters of brand new 10w50 sae oil. New 30 am blade fuse to replace the BURNT (not just blown, but black and crusty) dogbone fuse.
Im trying to UNrat-screw this bike. I can look at it and tell im already in love with it. So it want it to look good, run good, and be correct.
Which brings us back to the problem: I domt know what the heck im doing, now getting into the guts of the electrical system.
I THINK its something to do with the coils, but I dont know how to test them (yes I know volt/ohmmeter, but thats it). Dont know where im supposed to be touching or which setting or anything. Im totally lost without a paddle here.
Goldwingjosh is offline
post #2 of 7 (permalink) Old 04-19-2014, 01:14 PM
Welcome to the forum, Josh.
I'm a little confused. Have you had the bike running, and then it quit?
When you check for spark, is it not getting spark on either side? If you're not getting spark on either side then it's probably farther up the line than the coils. Might be as simple as a dirty kill switch, but the 'lec-trick wizards will need to know more.
post #3 of 7 (permalink) Old 04-19-2014, 01:44 PM
glhonda's Avatar
Be advised the original bike utilized points and condensers. Remove the rear cover on the left head (as you're sitting on it) and see if the points are still there, or been replaced by a reluctor and pick up coils.
glhonda is offline
post #4 of 7 (permalink) Old 04-19-2014, 05:05 PM
killer driller
jon jay's Avatar
Model: 1999 1500se,1986 gl1200
+ 1 on pts and condensers also how long did the bike sit is it getting fuel, carbs could be gummed up, give some history on bike please and welcome to the forum
"ride safe my friends"
jon jay is offline
post #5 of 7 (permalink) Old 04-19-2014, 05:47 PM
Cyclebusters.com
Cyclebuster's Avatar
Year: 67, 68, 69, 70, 71, 72, 73 74, 75, 76, 80, 81, 82, 83
Make: Honda, Suzuki Kawasaki, Triumph BSA
Model: Standard, Interstate, Aspencade.
Step 1. Locate local Goldwing Guru.
Step 2. Admit ignorance and ask for help.
Step 3. Listen. Learn. Read.
Step 4. Follow directions exactly.
ANYWAY..behind the left front of the tank shelter cover is a wire bundle. there is a small bundle going to the coils. in that bundle is a pair of black wires with white tracers. that wire should have 12v with the key and kill switch in the run position. once you have that, check for 12v at the points. If so, Adjust them properly from the manual you just downloaded. it should run.
Current toys
69 BSA Rocket 3, 69 H1, 68 T500 Cobra, 71 Trophy 650, 72 CB750, 73 CB750, 74 CB750, 76 CB750, 72 S2/500 hybrid, 81 Gl1100 Standard, 71 A1SS, 71 H1, 78 SR500, 81 Honda MB50, 75 GL1000, 76 GL1000, 76 Goldwing Gl1000 LTD, 82 GL1100I, 82 GL1100A, 83 GL1100 Standard.
Cyclebuster is offline
post #6 of 7 (permalink) Old 04-19-2014, 06:34 PM
Unofficial Youtube Addict
Happytrails's Avatar
Model: 1991 Goldwing SE Anniversary Edition
Seems like most older Wings need some TLC so situation is about normal Don't know anything about your bike but rely heavily on the forum guru's and there help can guide you thru pretty much anything.
Happytrails is offline
post #7 of 7 (permalink) Old 04-19-2014, 07:22 PM
If you would put where you live in your profile, Texas is a big place, you might have a goldwing guru next door.
1977 GL1000 won't start ss17goku Goldwing Technical Forum 14 05-21-2012 06:52 PM
78 GL1000 won't start wanger55 Goldwing Technical Forum 7 07-18-2008 05:11 PM
1975 GL1000 Won't Start tmoreau Goldwing Technical Forum 16 11-27-2006 11:39 AM
HELP!! GL1000 won't start after carb rebuild Pro_Marinero Goldwing Technical Forum 13 07-28-2006 06:56 PM
Bike won't start, GL1000 mag Goldwing Technical Forum 22 06-27-2005 03:47 PM
