FI codes on gl1800 Trike - Steve Saunders Goldwing Forums
post #1 of 14 (permalink) Old 05-01-2014, 03:07 PM Thread Starter
Model: 2003 GL 1800 Trike
How can I retrieve the FI codes when I don't have a kick stand to get the codes Thanks and GOD Bless
wingman37333 is offline
post #2 of 14 (permalink) Old 05-01-2014, 05:20 PM
gl 1800 mil code
that should take care of your questions.
post #3 of 14 (permalink) Old 05-01-2014, 05:22 PM
I have a question.
Just specifically what does the acronym 'MIL' mean?
post #4 of 14 (permalink) Old 05-01-2014, 07:02 PM
It aint rocket science
DriverRider's Avatar
Model: The best
Malfunction Indicator Lamp
J.D.
Internet myth buster
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
DriverRider is offline
post #5 of 14 (permalink) Old 05-01-2014, 07:22 PM
Find the side stand switch connector, the switch may still be attached and just turned to the "up" position or it may be jumpered between the green/white and green wires, either turn the switch until the side stand light comes on or remove the jumper and connect it between the green and yellow/black.
post #6 of 14 (permalink) Old 05-01-2014, 07:31 PM Thread Starter
Thanks Have A bless day
post #7 of 14 (permalink) Old 05-02-2014, 06:41 AM Thread Starter
OK they cut the wires I found them and pulled a code 25 witch is left Knock sensor well where is it located Thanks Have a Bless day
post #8 of 14 (permalink) Old 05-04-2014, 07:51 AM Thread Starter
GL 1800 FI codes
I got a code 25 so I switch the left and right knock sensor And still got same code Where do I go from here
post #9 of 14 (permalink) Old 05-04-2014, 01:29 PM
Larry's Avatar
Model: 99 1500 SE
Thanks John, AZgl1500. Your link led me to find out what I needed to do to get the FI code that I could not get before.
Now that I know you must wait until the FI light goes on and then stop & put the side stand down without shutting the bike off to get the blinks. A couple of experts local "Experts" just started the bike on the side stand and waited for codes. Needless to say that did not get codes. So I followed the directions on the link and I get a code 25 just like wingman37333.
wingman could you PM me with the location of and directions to find the left Knock sensor.
Thanks in advance,
Larry
Larry
Retired, Lazy, Broke, and riding the Wing every day that I aint out fishin!
Larry is offline
post #10 of 14 (permalink) Old 05-04-2014, 06:53 PM
You will need to check for continuity/short to ground in the wire from the knock sensor to the ECM. Red/blue wire in the center of the grey connector. Code 25 on yours is the right knock sensor BTW.
Thanks in advance,
Larry
Code 25 pre 04 is the right knock sensor, located on the bottom of the right head just inside the front exhaust port.
How to read diagnostic codes on a 2005 GW trike PickyBiker Goldwing Technical Forum 5 08-19-2012 02:34 PM
gl1800 trike 2008 saltmar14 For Sale/Wanted Forum 1 08-28-2011 07:16 PM
GL1800 Trike DeerWrangler Goldwing Technical Forum 5 02-11-2011 06:37 PM
Trike performance GL1800 Mike Fuller Goldwing Technical Forum 2 09-13-2009 09:18 PM
GL1800 Trike For Sale TexasTrike For Sale/Wanted Forum 19 01-16-2006 01:17 PM
