1988 gl1500 vacuum lines and what be eliminated - Steve Saunders Goldwing Forums
post #1 of 3 (permalink) Old 05-16-2014, 07:24 PM Thread Starter
Fastymz's Avatar
Model: 1988 GL1500
I pulled the carbs off my 88 gl1500 to rebuild them. Before putting it all back together are there any vacuum lines or valves I can eliminate without causing running issues. The bike is a California bike so its has extra items that 49 state bikes don't. It also has the high altitude valve. I'm replacing all the vacuum lines and carb insulators and thought if there valves that can be left off nows the time to do so. Thanks Ron
Ron
1988 GL1500 76000miles
1986 Honda 700F VFR 39000miles
Fastymz is offline
post #2 of 3 (permalink) Old 05-16-2014, 09:08 PM
Model: 88 gl1500
On my 88 (49 state model). I replaced ALL the vacuum hoses that was connected directly to the intake! I think there are 2 different sizes. Take them to your favorite auto parts store and get 3-6 feet of each. The hose between the 2 boots would be first! Then the one on the left side intake. Those are the 2 most common failure ones.
bones200 is offline
post #3 of 3 (permalink) Old 05-17-2014, 08:37 PM Thread Starter
Fastymz's Avatar
Model: 1988 GL1500
Any know if I can remove any of vacuum valves or plug any of the lines without issues ?
Ron
Fastymz is offline
1988 GL1500 Vacuum Item jp in mn Goldwing Technical Forum 5 11-20-2012 04:12 PM
??????'s on GL1500 carbs, vacuum lines, and other problems goldwingmike88 Goldwing Technical Forum 8 07-31-2011 04:06 PM
GL1500 vacuum lines dwsonar Goldwing Technical Forum 6 05-08-2011 04:39 PM
1988 gl1500 vac lines replacement HELP! Dave549 Goldwing Technical Forum 1 10-03-2010 11:37 AM
Ageing Vacuum Lines on a GL1500 N5HQ Goldwing Technical Forum 8 07-16-2009 05:36 AM
