1200 rear shocks not holding air - Steve Saunders Goldwing Forums
post #1 of 9 (permalink) Old 05-17-2014, 10:52 PM Thread Starter
Model: 1200 Aspencade
So I've read/viewed the rear shock rebuild thread and also looked at replacement shocks but have a question. On page 342 Clymers it stays if air leak is suspected remove air valve fitting from the top of the shock absorber and replace the o-ring. What are the chances this is the problem, seems simple. What are the other reasons for replacing are there other failures other than not hold on pressure? Thanks.
f5guy is offline
post #2 of 9 (permalink) Old 05-18-2014, 12:12 AM
Why not use some soap and water to find the leak(s)?
Ken Bergen is online now
post #3 of 9 (permalink) Old 05-18-2014, 07:20 AM
Model: GL1200A
+1 beats taking shocks off
cowboy76 is offline
post #4 of 9 (permalink) Old 05-18-2014, 08:05 AM
There are several places that system can be leaking air from. From the compressor all the way back to those afore mentioned o-rings.
post #5 of 9 (permalink) Old 05-18-2014, 08:17 AM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
http://www.westernhonda.com/fiche_se...86&fveh=132540
JeffMayfield is offline
post #6 of 9 (permalink) Old 05-18-2014, 09:21 PM Thread Starter
Will get the soap out and report back ,the simplest ideas are usually the best. No compressor so this should be easy. Thank you.
f5guy is offline
post #7 of 9 (permalink) Old 05-18-2014, 09:47 PM
Just Winging It
Year: 1986
Make: GL1200I
Model: GL1200I 1986
I had to replace all 4 o rings and put oil in the shocks. I used a https://www.goldwingfacts.com/forums/...pair-tool.html this really helped the ride but I plan on doing a full rebuild of the shocks because the springs are weak and the bushings are likely wore out like the fork bushings were.
post #8 of 9 (permalink) Old 05-18-2014, 10:01 PM
Just Winging It
Year: 1986
Make: GL1200I
Model: GL1200I 1986
Blown oil seal
Cut or broken line
If you had a compressor maybe something there but I don't have one. So I don't know for sure.
post #9 of 9 (permalink) Old 05-18-2014, 11:32 PM
What happened to your compressor?
gl 1200 rear air shocks Fastymz For Sale/Wanted Forum 3 04-22-2013 10:26 PM
94 aspen rear shock holding air to coushonie marlin_1 Goldwing Technical Forum 7 03-10-2013 10:32 PM
Rear shocks not holding air, GL1200LTD jobe05 Goldwing Technical Forum 6 11-13-2011 04:11 PM
UK, Goldwing 1200 rear air shocks. Reconditioning ? KevS Goldwing Technical Forum 2 03-20-2007 05:34 AM
Rear air shocks, Goldwing 1200 Kevsauk Goldwing Technical Forum 6 10-03-2006 09:27 AM
