GL1100. Stupid is as stupid does - Steve Saunders Goldwing Forums
post #1 of 18 (permalink) Old 06-27-2014, 04:22 AM Thread Starter
Model: 3X 1976 GL 1000's 2X 1977 GL1000, 1981 GL1100
I am not in the habit of flaying myself in a forum of like minded, yet unknown, individuals however I feel I must if only to purge my rank stupidity in approaching a mechanical problem about which I have huffed on about laboriously on 2 websites.
All the engine building experience inthe world cannot help you if you don't recognize an obvious f**kup. I didn't.
I had replaced the head gaskets and done a valve job on my GL1100 sidecar rig and was complaining long and loud about knocking, synchronizing etc... Those problems were solved by using the correct spark plugs and actually checking the flow through the air filter (there wasn't any).
Now that the beast was running very smoothly, although smokey on startup, I smelled coolant and the level in the catch tank dropped. I deduced I had screwed up the head gaskets and decided to try a sealant as these items are pricey in Europe.
I got everything going, put the minimum amount of sealant in the system and let it idle. It was burbling away happily for 45 minutes when I noticed the catch tank filling. It then started pouring coolant out the drain hose replicating a blown head gasket pressurizing the cooling system.
Then I noticed what was wrong: the PO, who sold me the bike because of a blown head gasket, had put the hoses on the wrong fittings on the catch tank. The radiator cap was doing it's job of evacuating excess pressure in the form of vapor, which was pressurising the tank and forcing liquid out the drain hose. I inverted the hoses, the catch tank began draining back into the radiator and the world is once again safe for democracy.
I post this self humiliation to warn all those who think they might have a major problem with their motors that could be caused by a simple oversight.:wtf: Thanks for your attention; you may now go back to more interesting posts.
Cheers,
Zaphod
Writing roughshod over the English language
Phavas is offline
post #2 of 18 (permalink) Old 06-27-2014, 05:20 AM
Yes, everyone needs to smite themselves once in a while, and own up to it.
My question is ,since when is Maine in Europe?
post #3 of 18 (permalink) Old 06-27-2014, 05:57 AM
Model: GL1100
Don't feel bad. The other day my father in law calls me to ask if I could help him get his scooter running, he had been messing with it for 2 days and couldn't get it to fire up. I ended up playing with it for an hour with no luck until I decided to take a closer look at the handlebars and noticed a switch with odd symbols just above the starter button and that made me go "hhmmmm". There was nothing that clearly said on/off like the kill switch on our right hand controls, just strange symbols so just for kicks I moved it to it's middle position ....... and it fired right up when I hit the starter button. DOH!!. I was pissed at myself that it took me an hour to think of it because it's normally the first thing I check and my father in law was thoroughly embarrassed with himself because he didn't think of it at all.
JSBail is offline
post #4 of 18 (permalink) Old 06-27-2014, 06:41 AM
wingsam41's Avatar
Clearly he is situated in tha main part of Europe-he just misspelled...
wingsam41 is offline
post #5 of 18 (permalink) Old 06-27-2014, 06:57 AM
Year: '95
Make: GL1500SE
Model: '86 Gl1200 Sold
My friend who runs a shop said that in the past month he has some customers come back complaining about his work, the quads or bike would not run. All of them he was able to get running real quick. 2 of them was just like what JSbail had done, the on/off switch was in the "off" position. Then he had one that didn't have any gas. The rest was real simple things also. Must be a full moon.
tprender is offline
post #6 of 18 (permalink) Old 06-27-2014, 08:02 AM
Trike Master
tfdeputydawg's Avatar
Model: 06 levelIII/Hannigan
Good thing I've never done anything like that, AHHH wait a minute, yes I have..............Never mind!!!!!!!!!!!!!!!
tfdeputydawg is offline
post #7 of 18 (permalink) Old 06-27-2014, 12:32 PM
rayjoe's Avatar
Originally Posted by GL1200VirginiaUSA View Post
I also was curious when they moved Maine across the Atlantic. No wonder I didn't do too well in geography.
Forget Global Warming, it's Continental Drift that's the real problem!!
Rayjoe
rayjoe is offline
post #8 of 18 (permalink) Old 06-27-2014, 12:46 PM
wexy's Avatar
Year: 2003
his IP address is in France
CIARAN (pronounced Keeron)
yes it is Gaelic
wexy is offline
post #9 of 18 (permalink) Old 06-27-2014, 12:54 PM
mh434's Avatar
Model: 1997 GL1500SE
Phavas - very eloquently written post, indeed! As for the nature of your post, well, none of us who have ever done mechanical repairs to any extent have avoided such self-induced face-palm moments. I've been wrist-crankin' and wrench-turnin' for lo, these past four and a half decades, yet I still fall prey to my own internal, infernal assumptions while working on machines, blinded by them, unable to see my own most obvious blunders.
When we share our mistakes, we all, as a community of sorts, profit by the knowledge and are enriched by it.
I thank you, sir!
mh434 is offline
post #10 of 18 (permalink) Old 06-27-2014, 12:59 PM
tfwarner23's Avatar
Year: 2001
Make: Harley Davidson
Model: ULTRA CLASSIC ELECTRA GLIDE - EFI
Send a message via Skype™ to tfwarner23
that kill switch has gotten me once
Thomas
OPMC - Our Place Motorcycle Club
ABATE of ND - Board of Director
"Lets Ride Together"
GWRRA - Capital Wing Riders, Chapter C
2001 HARLEY DAVIDSON ULTRA CLASSIC ELECTRA GLIDE - EFI
1995 GL1500SE
Previous Owned
1984 GL1200I
1979 Yamaha 650 Special II
1981 Yamaha XV920R
1984 Suzuki GS1100GKE
tfwarner23 is offline
Damn, Stupid stupid stupid.....Arggggg!!! ThFireman Goldwing Technical Forum 52 11-13-2009 11:04 PM
Stupid GL1100 crossover tubes! brianinmaine Goldwing Technical Forum 3 08-23-2009 03:06 PM
Stupid Stupid Man wolfblade Fun Forum 3 11-01-2008 03:37 PM
Stupid GL1100 question jsmith24 Goldwing Technical Forum 18 10-24-2006 04:33 PM
How Stupid Can You Get? teacher Fun Forum 0 12-12-2005 09:22 PM
