gl 1200 front brake disc/rotor - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 07-03-2014, 01:50 PM Thread Starter
hi,was this type of disc fitted to any other bikes,mine is a 1984.
just noticed mine is cracked in 3 separate places but cant find any for sale in the uk.
cheers,Bash
basher is offline
post #2 of 6 (permalink) Old 07-03-2014, 02:53 PM
WingMan71's Avatar
Year: 2006
Model: GL1800, GL1200, GL1000
cheers,Bash
Bash,
They come up for sale regularly on eBay. So you CAN find them.
All the Gold Wing GL1200s (1984, 1985, 1986, and 1987) use the same brake rotors.
But, there are two different types of rotors depending on the model of the Gold Wing. All the Interstate models (and the 1984 Standard model) use non-vented (solid) rotors. All the Aspencade models use vented rotors which are over twice as thick.
If you find some rotors, make sure they still have some life left in them. The service limit thickness for the Interstate rotors is 4mm. The service limit thickness for the Aspencade rotors is 9mm.
So, don't waste your money buying rotors that are under that thickness.
If the seller didn't advertise or won't measure the thickness for you with a micrometer or other similar tool, don't buy from them. Look for a seller that has measured the rotor thickness and put that info in their ad.
You should be able to find a set on eBay.
Good luck with it.
Bob
2006 Arctic White GL1800
1987 Black/Grey GL1200 Aspencade
1976 Special Candy Maroon GL1000 LTD
1971 Blue CL100S Scrambler
U.S. Navy SWO (1967-1976)
WingMan71 is offline
post #3 of 6 (permalink) Old 07-03-2014, 04:12 PM
I wouldn't bother looking on Evilbay as most would be worn out or close to it and across the pond so shipping cost would be an issue.
EBC does make replacement rotors which should last for 100,000 miles or more and as they're made in the UK shipping shouldn't be an issue.
Ken Bergen is online now
post #4 of 6 (permalink) Old 07-03-2014, 05:00 PM
oldcomputek's Avatar
Model: 1987 GL1200 Interstate
What Ken Said ^^^ and here you go vvv. Not cheap mind you but as good as Mother Honda AFAIK. Hope that helps..... John
http://ebcbrakes.com/where-to-buy-in...-uk-motorcycle
http://www.ebcbrakesdirect.com/bike/...-86%29&sec=Jap
In the Past
1966 Harley Davidson 50 2-cycle
1969 Yamaha 125 Enduro
1970 Yamaha 90 MX
1973 Yamaha RD250
1974 Yamaha DT 360 Enduro
1975 Can Am MX-2 125
1975 Honda CB550
1978 Yamaha XS650
1979 Harley Sportster XLS
1982 Honda Ascot FT500
1972 Harley Davidson 1200FL
1972 Harley Sportster Custom
1982 Honda CB550
Current bikes
2007 Tank Urban 150
1987 Honda GL1200I
1986 Honda GL1200SEI
Plus a few others Iíve forgotten but still have the scars from!
oldcomputek is offline
post #5 of 6 (permalink) Old 07-04-2014, 03:36 PM Thread Starter
thanks guys,
apparently the Honda vf750 has the same discs and theres plenty of them on "evilbay" lol. could be useful information for others over here.
cheers,Bash
basher is offline
post #6 of 6 (permalink) Old 07-04-2014, 03:56 PM
thanks guys,
cheers,Bash
Where did you get that information?
I looked on Evilbay and they appear to be a flat rotor not dished like the GL1200 rotors, the mounting circle appears to be much larger than the GL1200 rotors and they seem to be solid 5mm(?) rotors not vented 10mm rotors as used on your Aspencade.
Which front brake disc on GL1500 controlled by hand lever? tnoort Goldwing Technical Forum 11 05-11-2012 02:58 AM
1983 GL1100I Rear Brake Disc(Rotor) Archameleous Goldwing Technical Forum 7 12-21-2011 09:04 AM
front brake disc on an 83 Aspy Chauncey Goldwing Technical Forum 3 08-23-2011 06:46 PM
GL 1200 Rear Brake Disc frankiemk Goldwing Technical Forum 6 03-14-2011 10:13 AM
rear disc brake rotor 82 1100 kenmschwarz Goldwing Technical Forum 11 11-20-2004 03:13 PM
