94 1500 leaking coolant above the timing belts only when hot - Steve Saunders Goldwing Forums
post #1 of 12 (permalink) Old 07-26-2014, 11:53 PM Thread Starter
We ride...'s Avatar
Model: Goldwing 1500 Aspencade
Guys,
The wing is leaking from above the timing belt cover, seemingly onto the top of the left rad, and only when we get to 3/4 heat.
Also, she's idling warm in traffic, and so when she does leak, its a steady splatter/spray of the fluid.
dislodged the rads to see behind, but i'm not seeing anything from there.
Am i losing my thermostat or what here?
thanks,
Kyle & Sandra
Old Guy & the Troubadour
1500 Aspy w/ Tiny Mate pop up trailer
Pearl Atlantis Blue
We ride... is offline
post #2 of 12 (permalink) Old 07-27-2014, 12:58 AM
Cornpone's Avatar
Sure your radiator cap isn't "burping?" Normally when coolant is on top of an engine, I think highest place first = radiator cap; then upper radiator clamp/hose, coolant overflow tank leaking, then engine coolant tubes, and eventually lower stuff.
Cornpone is offline
post #3 of 12 (permalink) Old 07-27-2014, 10:35 AM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
Originally Posted by We ride... View Post
...leaking from above the timing belt cover, seemingly onto the top of the left rad, and only when we get to 3/4 heat.
Also, she's idling warm in traffic, and so when she does leak, its a steady splatter/spray of the fluid....
Sounds like the hose has come off the Top of your Thermostat, which is a common problem. Look carefully at the large Y-shaped hose coming off the top... notice that it should be full seated against some Stops molded onto the neck of the thermostat... if not, then the hose may have slid upwards, at which point it will leak whenever the thermostat opens (at high temps). Simply loosen the hose clamp, slide the hose back down, then re-tighten.
-You'll have to remove at least one fan to access the thermostat.
-When it leaks, and bike is on side stand, the leak will end up on lower left corner of timing belt cover.
-Before reattaching the hose, verify that there is no Clear Tape on the neck of the thermostate... If there is, then remove it. The tape is common, on some 1500's, to all the hose joints to the radiator too... it causes the hoses to slide off, leak.
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #4 of 12 (permalink) Old 07-27-2014, 12:51 PM Thread Starter
We ride...'s Avatar
thanks Alex and Cornpone...
the bike is centered on a hoist and the cap doesnt appear to be burping it out when we're testing it. To clarify, a small dribble falls on the left side of the timing belt ĉover, then shortly thereafter, its dumping left and right.
I shall pull the fan and look in from the left side.
Of course, we cant see the bottom of the reservoir, with it in place, and i wonder if by pulling the reservoir tank to investigate, i'll simply negate the right conditions for it to leak. What is the best approach to inspecting the res tank and upper hoses?
thanks
Kyle & Sandra
Pearl Atlantis Blue
post #5 of 12 (permalink) Old 07-28-2014, 12:43 AM Thread Starter
We ride...'s Avatar
you called it, Alex. Top hose on the thermostat. Clamp had rusted through.
Cut away that goofy tape and replaced all the clamps with ss.
Thanks again.
Kyle & Sandra
Pearl Atlantis Blue
post #6 of 12 (permalink) Old 08-06-2014, 09:39 AM
WingEMT's Avatar
Year: 1994
Model: GL1500 SE
Thanks again.
Curious as to how you saw/accessed it easily? I am having damn near the exact same problem on my 94 SE. I did notice that the grommet is cracked for the elbow in the overflow tank also.
1994 GL1500SE with CycleMate trailer
WingEMT is offline
post #7 of 12 (permalink) Old 08-06-2014, 09:52 AM
Originally Posted by WingEMT View Post
Curious as to how you saw/accessed it easily? I am having damn near the exact same problem on my 94 SE...
With either of the fans removed, you can readily view any leak coming from the thermostat (Which tends to appear when the engine warms up about half-way, at the time the thermostat opens, sending water upwards into the Y-shaped rubber hose above it)
I void warranties
KJ6QFZ
Dark Side #590
post #8 of 12 (permalink) Old 08-06-2014, 11:52 AM
WingEMT's Avatar
Year: 1994
Model: GL1500 SE
Thanks much for the quick response. I didn't know if I needed to remove a fan to see it. Or if so, which side? Thanks much.
WingEMT is offline
post #9 of 12 (permalink) Old 08-06-2014, 11:59 AM
WingEMT's Avatar
Year: 1994
Model: GL1500 SE
Quick follow up question.
If that is not the cause of my leak, are all of the smaller coolant and vacuum lines accessible from the sides where the fans are removed? Should I drain the coolant and remove the radiators regardless to get them out of the way? I am trying to disassemble as little as possible. I do have a new Beck Arnley thermostat and gasket on hand.
Thanks again. All of your wisdom is appreciated.
WingEMT is offline
post #10 of 12 (permalink) Old 08-06-2014, 07:04 PM
I didn't know if I needed to remove a fan to see it. Or if so, which side?...
Either Fan will give you visable access to the thermostat, in order to discern a leak. If a leak is present, then you'll have to access the Screw Head on the hose clamp (to the Y-hose)... If you're lucky, then you can access it from whatever side (fan) you just removed, otherwise you'll have to remove the other fan as well.
Hint: The right side fan is easier to remove than left side.
Hint: When reinstalling fan, Ok to leave out the upper-rear-most screw... it's not needed, and makes future removal/installation easier; also helps to replace the remaining screw/s with (SHCS)Socket Head Cap Screws, which can very/more easily be turned with an ball-end allen head wrench.
...If that is not the cause of my leak, are all of the smaller coolant and vacuum lines accessible from the sides where the fans are removed? Should I drain the coolant and remove the radiators regardless to get them out of the way?...
No, some of the coolant lines are beneath the carb, requiring removal of the carb. That said, the typical leaks are from the joints to the Thermostat and radiators, due to presence of "clear tape" on the mating surfaces for the hoses.
No, most all the vacuum lines are beneath the carb, and under the left intake manifold. You won't see any more/less of them by removing the fan/s
No need to remove the radiator for this first step of Finding the Leak... With one or both fans removed, you will have very good visual on many coolent hoses.
I void warranties
KJ6QFZ
Dark Side #590
1500 timing belts happer Goldwing Technical Forum 4 08-18-2011 11:19 PM
GL 1500 Timing Belts 6adan Goldwing Technical Forum 3 09-15-2010 02:36 PM
Timing belts on 1500.... again 1-Shot Goldwing Technical Forum 25 05-06-2009 05:12 PM
Changed Timing belts Now Antifreeze leaking Hawaii Goldwing Technical Forum 5 10-22-2008 07:31 PM
Timing belts for my 1500 ELKMAN121 Goldwing Technical Forum 5 05-14-2008 12:52 PM
