GL1500 need help wiring a delay relay to HID's - Page 3 - Steve Saunders Goldwing Forums
 3Likes
post #21 of 31 (permalink) Old 05-01-2016, 12:32 PM
Dave,
Actually all he needs is Relay #2 by itself.
It does not matter that #30 and #85 are "always hot to battery", and there won't be a ground source UNTIL the oil pressure switch "makes to ground".
And that will never happen unless the engine starts and runs.
post #22 of 31 (permalink) Old 05-01-2016, 02:50 PM
Dave,
No, the opposite is true, the oil pressure switch is grounded when there is no oil pressure.
post #23 of 31 (permalink) Old 05-01-2016, 03:57 PM
Duh, you got me there Dave
Twas I that didn't think that one through.
post #24 of 31 (permalink) Old 05-01-2016, 04:14 PM
Professional Curmudgeon
Davek's Avatar
Model: GL1800 ABS
This should do it, unless I missed something. Your kit should have the wire coming from the battery + so all you have to do is wire the relays into it. I may have to translate the writing.
So does that mean the the #87 on the 2nd relay goes to the ground on the HID lights? Or the positive wire for the HID lights?
Sorry, I'm not good at this.
God gave his Arch Angels weapons because even the Almighty knew you don't fight evil with tolerance & understanding.
Davek is offline
post #25 of 31 (permalink) Old 05-01-2016, 04:39 PM
That's 87A, goes to the + to the HIDs.
post #26 of 31 (permalink) Old 05-01-2016, 04:59 PM
Davek's Avatar
Model: GL1800 ABS
Thank You!
Davek is offline
post #27 of 31 (permalink) Old 05-01-2016, 05:26 PM
Davek's Avatar
Model: GL1800 ABS
Originally Posted by Happytrails View Post
I threw together a rough diagram to show what I was thinking. Let me know if this will work. Thanks.
If you have time could you make this into a diagram with the 2nd relay 87A going to the + of the HID lights? I think it would help a lot of the users here.
Thanks in advance.
Davek is offline
post #28 of 31 (permalink) Old 05-01-2016, 05:56 PM
Silverado6x6's Avatar
Year: many years, two different continents.
Model: 2035 GL3500 Intercontinental
With the newest LED bulbs available i'm rethinking about converting AWAY from HID, The failure rates of the hid kits are so bad its 50%, thats at least one bad ballast in each kit. Usually its the slim ballast. Those Pathfinder led bulbs look very promising. They use flexible woven mesh straps for heatsinks instead of the big chunks of heatsinks, better to fit in a confined space, plus an led bulb can be restarted immediately, and modulated, hids cannot be modulated.
After i just posted this i bought these to test out.
http://www.ebay.com/itm/152056235707...%3AMEBIDX%3AIT
Silverado6x6 is offline
post #29 of 31 (permalink) Old 05-02-2016, 11:52 AM
Davek's Avatar
Model: GL1800 ABS
I'm no expert and just trying to make sure I understand it correctly.
Please look at this PDF I made and tell me if I have it wired correctly.
File Type: pdf GL1500 HID Headlight Delay using Oil Pressure Relay Activation.pdf (30.7 KB, 20 views)
Davek is offline
post #30 of 31 (permalink) Old 05-02-2016, 04:00 PM
Great, way better job than I did. I saved it for future use.
Time Delay Relay for HID Headlights, GL1500 Knob Goldwing Technical Forum 2 03-08-2014 09:37 AM
I give up GL1500 HID light wiring wing in atlanta Goldwing Technical Forum 24 10-27-2013 09:55 AM
GL1500 Relay 3 burnt wiring fordf3truck Goldwing Technical Forum 1 07-24-2013 04:16 PM
Cruise switch delay GL1500 [email protected] Goldwing Technical Forum 3 11-26-2012 10:14 PM
GL1500 relay wiring ginger68 Goldwing Technical Forum 4 07-14-2012 09:02 AM
