Low compression - Steve Saunders Goldwing Forums
post #1 of 13 (permalink) Old 10-07-2014, 05:25 PM Thread Starter
cromagjeff's Avatar
Model: 1988/1500
Low compression
1988 GL 1500 #1/150lbs, #3/130, #5/#150. #3 has a wet plug that is getting spark. Appears that oil is on the plug. #5's plug appears to be burning very hot has almost a white look to the plug. #1's plug has a nice amber color.
What can I say, I\'m just a caveman.
cromagjeff is offline
post #2 of 13 (permalink) Old 10-07-2014, 06:15 PM
Anti-Guru
satan's Avatar
Model: '06 GL1800
#3 & #2 are the most likely to foul/flood if you have drippy carbs (especially if your fuel petcock runs fuel with the bike off). Is your 88 equipped with the vacuum fuel petcock mentioned in 1500SB1 about carb vent hose routing (on this page **link**)
The compression numbers you have are not terrible... The manuals all mention stuff about higher values, but a 9.8:1 ratio pumping one atmosphere (14.7 psi @ 60F) is near 144psi without heating... and folks forget that the sliders on the 1500's carbs are nearly closed unless you're forcing them open. I don't know if I've ever seen a 1500 here that has anything better than your high values, and 130 is 7% lower, but nothing that shouldn't work
satan is offline
post #3 of 13 (permalink) Old 10-07-2014, 06:32 PM
It aint rocket science
DriverRider's Avatar
Model: The best
The no. 3 cylinder on the 88 is where the vacuum source is for the fuel petcock and if the diaphragm is blown it can suck gas straight into the cylinder.
J.D.
Internet myth buster
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
DriverRider is offline
post #4 of 13 (permalink) Old 10-08-2014, 05:49 AM Thread Starter
cromagjeff's Avatar
Model: 1988/1500
Just ordered a petcock rebuild kit. Plan to start there. Also plan to run Seafoam through the crank case and inject directly into the #3 cylinder.
post #5 of 13 (permalink) Old 10-08-2014, 09:16 PM
tire joe's Avatar
Model: 1985 i
Why?
I want ride Tire Joe
tire joe is offline
post #6 of 13 (permalink) Old 10-08-2014, 09:26 PM
84GrayWing's Avatar
Model: 1983 GL1100 & 1977 GL1000
I agree with the sea foam. I've run it in all my older stuff and it seems to clean well. If you winterize, don't use it in that tank of gas, use stabil.
Jeff
USN Ret 1985 2005
Wild Rhinos
Oklahoma Chapter
Present Bikes in the stable
2007 KLR650
1983 GL1100 Full Dress
1977 GL1000 Nekkid
84GrayWing is offline
post #7 of 13 (permalink) Old 10-09-2014, 09:45 AM
fatwing chris's Avatar
If #3 is getting too much fuel the cylinder walls will be washed,hense the low compression on that one.Fix the fuel problem and your compression will come back in line.
Fatwing Chris
Darkside #1602
Gone Double Dark with a BT45
fatwing chris is offline
post #8 of 13 (permalink) Old 10-09-2014, 01:21 PM Thread Starter
cromagjeff's Avatar
Model: 1988/1500
Got to start somewhere so I know my petcock is leaking. Can't hurt to rebuild.
post #9 of 13 (permalink) Old 10-09-2014, 02:34 PM
mrtwowheel's Avatar
Model: 1986 GL1200I
Test, Test, Test parts before replacing them. A little vacuum and the test is done. If you can use a straw you can test a vacuum petcock for diaphram leaks. Ask or search "how to test" before replacing parts and throwing your money away, or buy a new bike every few years.
Scott
Send lawyers, guns and money
1975 GL 1000, Fermenting
mrtwowheel is offline
post #10 of 13 (permalink) Old 10-12-2014, 11:24 AM Thread Starter
cromagjeff's Avatar
Model: 1988/1500
It"s alive!!!!!
After chasing a cylinder miss DriverRider mentioned that the #3 cylinder was the vacuum for the petcock. Looking at other Goldwing forums others agreed. I ordered the petcock rebuild kit from Cyclemax. I followed the video tutorial for rebuilding the petcock on Big Bikes Parts. Took longer to get to the petcock than it did to rebuild the petcock. Put it back on the bike and bam the power is back and the miss it gone! Thank you DriverRider . For once I started the simple and worked my way forward. Awesome forum.
GL1100 low compression mad dog 60 Goldwing Technical Forum 18 07-01-2012 04:37 PM
GL 1200I low compression bwills6 Goldwing Technical Forum 15 03-25-2012 07:24 PM
GL1200 low compression pms Goldwing Technical Forum 9 04-03-2010 09:16 AM
Low Compression thessler Goldwing Technical Forum 17 12-05-2007 06:49 PM
Low compression, GL1100 LD Hack Goldwing Technical Forum 11 03-18-2006 08:12 PM
