Is the 92 SE starter/cruise control different from the non-SE control - Steve Saunders Goldwing Forums
post #1 of 7 (permalink) Old 11-22-2014, 10:04 AM Thread Starter
chas's Avatar
Model: 1992 GL1500 SE
I need to replace my starter/shift control switch on my 92 SE. I see GL1500 switches on fleabay but the part number for them is 35130-MT2-003. The fiche for the 92 SE shows a part number of 35130-MT8-771. Anyone know if I can use the non-SE version? On the fiche, the breakdown looks identical, but then why the different part if they are the same.
chas is offline
post #2 of 7 (permalink) Old 11-22-2014, 11:34 AM
flash2002's Avatar
Hi, they are the same, but why do you want to change it ? are they burnt maybe just need cleaning.
flash2002 is offline
post #3 of 7 (permalink) Old 11-22-2014, 04:35 PM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
The SE has lighted faces were the Aspencade has no lights which is what you're looking at on fleebay. Can you use it, yes.
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #4 of 7 (permalink) Old 11-22-2014, 04:58 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
The part number 35130-MT2-003 is for the Aspencade.
The part number 35130-MT8-771 is for the SE.
The differences is the SE has illumination and the Aspencade does not have illumination.
Look at the fiche again for the Aspencade, you will not see the following item numbers listed:
Item # 5 (Bulb)
Item # 13 (Bulb)
Item # 9 (Plate)
Item # 10 (Clamp A)
Item # 11 (Clamp B)
Note: They are shown in the picture but not in the listing.
Look at the fiche for the SE, you will see them listed.
DBohrer is offline
post #5 of 7 (permalink) Old 11-22-2014, 09:35 PM Thread Starter
chas's Avatar
Ah, thanks for the detail on the differences. I totally missed the bulbs. The set/decel button is not just sticking, it is actually loose. I did try cleaning it with some electric contact fluid, but it still does not move properly and gets stuck in the down position. When I pulled apart the control, I found that the housing for that button is broken. I think I can do without the illumination. Thanks for all the replies. Much appreciated!
chas is offline
post #6 of 7 (permalink) Old 11-23-2014, 04:51 PM
DBohrer's Avatar
Why not purchase the SE Switch Cluster, it is even cheaper........??
DBohrer is offline
post #7 of 7 (permalink) Old 11-23-2014, 06:41 PM
biker3777's Avatar
I just replaced my module but I dont think it was my issue,if I did not toss it you can have it for parts,I can tell you replacing that is a tough job.I will look for it.
Like to chase white lines,never caught one,
Other bikes,Honda 90,Kaw 350 A7,Kaw 500 Triple,Kaw 250 MCR,Husky 250 cr,Suzuki 250 Rm, ST 1100
biker3777 is offline
99 SE cruise control gford Goldwing Technical Forum 2 06-21-2012 03:59 PM
Cruise Control Cobra 1800 Goldwing Technical Forum 7 12-13-2010 04:05 PM
Cruise Control JC Springer Goldwing Technical Forum 16 05-03-2010 10:28 PM
Cruise Control maximo Goldwing Technical Forum 15 06-27-2007 07:49 PM
GL1500 Cruise Control and Emissions control equipment IanB Goldwing Technical Forum 6 08-22-2006 05:04 AM
