Allen head bolt under water pump - Steve Saunders Goldwing Forums
post #1 of 2 (permalink) Old 11-22-2014, 04:52 PM Thread Starter
Model: '92 GL1500SE
Hi i am replacing my water pump on my GL1500 and was wondering what the large Allan head bolt under the water pump was for, it runs from the bottom left of the motor on about a 30 deg angle to the upper right (when sitting on the bike.
just wonder if anyone can help.
chevelle69 is offline
post #2 of 2 (permalink) Old 11-22-2014, 05:05 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
It was there for assembly at the factory, you don't need to worry about it.
DBohrer is offline
GL1200 head gasket and water pump kits bluecamaro075 Goldwing Technical Forum 9 03-29-2012 05:58 PM
80 1100 should I replace just water pump or head gaskets? brianinmaine Goldwing Technical Forum 9 04-23-2010 10:42 PM
Got oil contamination and replaced Head Gaskets and Head and checked Water Pump?? Nightrider1 Goldwing Technical Forum 2 06-23-2009 01:32 PM
Urgent, Water Pump Drain Plug Bolt Leaking William_86 Goldwing Technical Forum 11 01-16-2008 12:27 PM
help to remove rounded allen bolt pinkpork Goldwing Technical Forum 11 08-13-2007 06:39 PM
