Speedometer Hub Question - Steve Saunders Goldwing Forums
post #1 of 8 (permalink) Old 01-11-2015, 12:29 PM Thread Starter
HeyJack's Avatar
Year: 2004
Model: GL 1800
1986 Gl1200A.........after I removed the hub assembly, I could not rotate the inside of it more than about 1/4" either way. There are 2 nubs on the inside of the hub that would catch on the 2 **** on the wheel making the inside of the hub turn as the wheel turns.
Question is....Should you be able to rotate the inside of the hub freely by hand?
Thx, Jack
"Some cause happiness wherever they go,
others, whenever they go"
-Oscar Wilde-
HeyJack is offline
post #2 of 8 (permalink) Old 01-11-2015, 05:18 PM
CastleWing's Avatar
Model: GL1500SE
disconnect the cable and re-try. if it still fails then clean the drive with paraffin/kerosene or what ever and check for obstructions like worn or broken teeth or grit. If when you disconnect the cable the gear runs free, then look to the cable.... disconnect at the clocks try to turn the cable if it runs free then suspect the gears in the clock.
Shiny side up, rubber side down.
Previous rides: Honda XL125S, Yamaha XS250, Honda CB250T, Honda CB400T, Honda GL500, MZ Simson 50, Kawasaki GT750, MZ 250/5, Honda CX500, Honda CB125S, BMW K100RS.
CastleWing is offline
post #3 of 8 (permalink) Old 01-11-2015, 05:51 PM
last child's Avatar
Model: 2010 GL 1800
Also clean up the sensor. Remove the 4 screws shoot it contact cleaner and put a small film of grease on the rotating piece.
last child is offline
post #4 of 8 (permalink) Old 01-11-2015, 06:27 PM
Thx, Jack
Yes it should turn freely and cause the output shaft to rotate.
post #5 of 8 (permalink) Old 01-11-2015, 07:09 PM
Some info Jack didn't mention is; he says the wheel inside sending unit, or whatever it is, spins when the wheel is rotated. That, to me, indicates that the gear is driving the unit...right?
Is that clear as mud?
We have tried to get the screw out that holds the sending unit to the gear, but it aint budging.
post #6 of 8 (permalink) Old 01-11-2015, 08:07 PM
last child's Avatar
Model: 2010 GL 1800
Yes I would agree. Not knowing it was still together as an assembly. I was thinking tear down has been done and you were in inspection/ diagnostic stage.
If none of the clean up of pieces were done at last front tire service. No need
to keep spinning the wheel and wondering. One or BOTH is dry.
post #7 of 8 (permalink) Old 01-11-2015, 09:16 PM Thread Starter
HeyJack's Avatar
Year: 2004
Model: GL 1800
Thanks everyone..................looks like it's time to grind a slot in the screw head and try the blade driver.
-Oscar Wilde-
HeyJack is offline
post #8 of 8 (permalink) Old 01-12-2015, 10:14 PM Thread Starter
HeyJack's Avatar
Year: 2004
Model: GL 1800
Finally got the sending unit seperated from the hub.
Was able to turn the small wheel of the sending unit and got the speedometer display to work. Just have to find a hub and should be good to go.
-Oscar Wilde-
HeyJack is offline
1985 GL1200 LTD Speedometer Hub eulas For Sale/Wanted Forum 0 07-21-2010 11:26 PM
WTB: Speedometer hub gear chris in va For Sale/Wanted Forum 1 05-31-2009 12:52 PM
Speedometer Gear Hub The Lake Goldwing Technical Forum 2 11-02-2008 05:02 PM
Rear Hub Question woody798 Goldwing Technical Forum 12 06-26-2008 10:43 AM
Rear Drive Hub Question woody798 For Sale/Wanted Forum 0 06-17-2008 02:34 AM
