2013 F6B Rear brake switch sticking - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 03-06-2015, 08:44 PM Thread Starter
stepbill's Avatar
Model: 2013 F6B
If I press the rear brake pedal and release it the brake light will not go off. I removed the right side cover by the rear master cylinder and pushed down on what looks like a brass plate and this reset the light switch. When I press back down on the rear brake pedal, it happens all over again. This only happens with the rear brake pedal. I tried spraying some electrical connector cleaner on it but that did not do anything. Can the tension on that plate be adjusted to put more pressure on it? My bike only has 3500 miles on it so far. Surprised this would happen already.
stepbill is offline
post #2 of 6 (permalink) Old 03-06-2015, 10:41 PM
Foodman's Avatar
Model: 2006 1800
Aren't you still under warranty.. Take it back to the dealer
Foodman is offline
post #3 of 6 (permalink) Old 03-07-2015, 12:14 AM
Unofficial Youtube Addict
Happytrails's Avatar
Model: 1991 Goldwing SE Anniversary Edition
Maybe it needs adjusted?. My rear brake pedal switch wasn't working and I fussed with it until I thought it might be bad. Played around with it some more and turns out it just needed adjustment. I cleaned it up and its working perfect again.
"riding is good therapy"
Happytrails is offline
post #4 of 6 (permalink) Old 08-29-2016, 07:27 PM
Guest
Year: 2013
Model: F6B
My front brake switch also stuck. I pulled it out with a dental pick, DW-40'd it and no more problems. Someone suggested I use silicone lube on it, I will if it happens again.
260969 is offline
post #5 of 6 (permalink) Old 08-29-2016, 09:59 PM
Yes there is an adjustment, the double nut on the push rod.
post #6 of 6 (permalink) Old 08-30-2016, 11:16 AM
cihilb's Avatar
Model: 2012 Pearl White
The plate that contacts the switch is held on with two screws . . Loosen them and move the plate until the switches work properly. The double nut on the rod adjusts the height of the pedal. I had to adjust mine after the brake recall. The pedal was about an inch too high.
cihilb is offline
2013 Goldwing F6B Sakryn General Motorcycle Discussion Forum 3 02-18-2013 04:33 PM
2013 Honda Gold Wing F6B Hondadiver General Motorcycle Discussion Forum 39 12-24-2012 10:25 AM
GL1100 Rear Brake lever sticking kayakinriverotter Goldwing Technical Forum 4 11-20-2012 08:12 AM
GL 1000 Rear Brake Sticking FredA Goldwing Technical Forum 4 09-25-2010 01:41 PM
Rear Brake lever sticking down rgouette Goldwing Technical Forum 15 07-29-2007 01:29 PM
