Front Fork Leak - Steve Saunders Goldwing Forums
post #1 of 11 (permalink) Old 04-03-2015, 11:45 AM Thread Starter
hondagw4m's Avatar
Model: GL 1800
Front Fork Leak
2003, 1800GL 57,498 miles front right fork seal started leaking. This is "pot hole" season here in Southern Va so I have been extremely watchful and so far have avoided them. I haven't read any reports of anyone experiencing leaking forks.
Any recommendations other then replacing / rebuilding the front forks?
Thanks
Brad
Riding on Angel Wings.
CMA Lighthouse Riders
Gloucester, Va
Where there is Light, there is no darkness
hondagw4m is offline
post #2 of 11 (permalink) Old 04-03-2015, 04:49 PM
Trike Master
tfdeputydawg's Avatar
Model: 06 levelIII/Hannigan
At 57K it's time for a rebuild!
tfdeputydawg is offline
post #3 of 11 (permalink) Old 04-03-2015, 05:11 PM
jackjohn's Avatar
Hi Brad, search on "fork seal" there are several hundred posts on the problem. It is time for a rebuild, probably at least with new springs, there are a number of ways to improve your suspension and handling available out there.
Jack
2012 GL1800A
2004 GL1800A Sold
1982 GL1100I Sold
1975 GL1000 Sold
1974 CB450 Sold
jackjohn is offline
post #4 of 11 (permalink) Old 04-03-2015, 05:28 PM
mh434's Avatar
Model: 1997 GL1500SE
If you want to give it a try, there are lots of threads out there about DIY fork seal cleaning tools (usually made from part of a plastic Coke bottle). From what I've read, something like 90% of seal leaks are from dirt between the seal & fork leg, rather than failing seals. It costs nothing - zero - to try it, other than 10 minutes or so time spent doing it, and it MAY solve your problem.
Here's a website (for professionally made seal cleaner tools), with a video on how they're used - http://sealmate.net/ - watch the video to the end!
They're a VERY simple tool (some people have even made 'em from leftover pieces of old 35mm film), and there are even patterns available for the DIY version.
Funny, 57K miles seems like a REALLY brief life for fork seals to me. I only ever had one leak (at around 100K), and even that one turned out to be dirt, rather than a failing seal (discovered after pulling them apart, of course!). Recently, I had a really bad leak in one of my Kawasaki seals (oil spewing all over the underside of the fairing on every bump) during a long ride. I found a plastic soda bottle on the side of the road, whipped out my pocket knife, cut out one of these tools based on what I remembered on the 'Net, cleaned out the seal, and *presto!* - leak cured. Didn't leak again after that, either.
I'm just sayin...
mh434 is offline
post #5 of 11 (permalink) Old 04-03-2015, 08:18 PM
Year: 94
Model: 1500 SE
is this why a cartridge shock is made for the 1800?
Aloha Tom is offline
post #6 of 11 (permalink) Old 04-03-2015, 08:35 PM
mrtwowheel's Avatar
Model: 1986 GL1200I
Yeah, check out Sealmate on You Tube. You can make one from a 2 litre pop/soda bottle. No exact measurements are needed. Notice the hook with a rounded point to pull the dirt up and out when you remove it. I buff the edges of the plastic with a Scotch-Brite pad. I use Walmart Tech Lubricant, similar to WD-40, to clean the fork tube, top of seal, and lubricate the tool before inserting it between the tube and seal. This has worked for me many times on many bikes. I get a real kick out of doing this for other people. Usually the fork has not even lost enough fluid to make any difference. Any bike that has sat for a while is apt to leak when first moved around. The Tech Lubricant limbers up the seals and the tool removes the dirt. Seals only close up when compressed, when moved the other way they can pull dirt in. New grease over the circlip will help the uninformed who may remove it in the future.
Scott
Send lawyers, guns and money
1975 GL 1000, Fermenting
mrtwowheel is offline
post #7 of 11 (permalink) Old 04-04-2015, 06:41 AM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
Thanks
Brad
Is the original oil still in the forks? If so the oil is toast and bushings are most likely bad too. The forks have to be removed to bleed out the old oil in the dampner. Cleaning the seal at this point is useless as you have lost oil and if it's over a year old or 2 yrs at most your fork action will be compromised and damage to the fork legs can happen shortly, which will require replacement if they get egg shaped as the fork tube will slop around.
You have the information to make the safe choice. It's your ride and those that you put on the back.
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #8 of 11 (permalink) Old 04-04-2015, 08:19 AM
Trike Master
As I stated, at 57K, you need a rebuild!
The suggested seal "repairs" are valid fixes for some leaking seals. However, you have no way of knowing exactly how much fork oil you've lost.
I replaced my fork springs @ 32K. One reason is I have triked and have a rake kit. But, again at 57K you are ready for new "springs"+ other internal items!
Also, never understood time intervals being used as when to change vs. mileage. IMHO, 50K woold be a good mileage to do the fork service.
I suggest you look at Progressive Mono-tubes:
http://www.progressivesuspension.com...9/monotube-kit
I have tested several options that are available and found these to be a good choice for 2 wheelers. Unfortunately, it seems Progressive has no plans to make these for trikes w/rake kits
post #9 of 11 (permalink) Old 04-04-2015, 08:33 AM
Still Learning
newday777's Avatar
So I take it progressive doesn't offer different spring rates on the monotubes?
In that case get the race tech gold valves and dampner mod with the heavier springs for @$350 parts retail plus labor for an economical option. You could even do the fork mod Dave0430 did putting in a dampner in the left fork to give more valving instead of just the right side only.
Stu
Previous bikes
post #10 of 11 (permalink) Old 04-05-2015, 02:25 PM
MichiganWing's Avatar
Model: 2007 Gl1800 HPN
Nope Tom. The monotube cartridge upgrade still uses 200-300 cc fork fluid in each side. Can still leak around a bad seal.
Shiny Side Up !
Jim
MichiganWing is offline
Front Fork seal leak 82 GL1100 kh7cp Goldwing Technical Forum 2 03-28-2015 06:01 PM
GL1100 Front fork oil leak shogun Goldwing Technical Forum 2 09-12-2013 05:51 AM
GL1500 front fork leak Ronaldws Goldwing Technical Forum 1 06-01-2010 01:44 PM
Front Fork Leak WingMan71 Goldwing Technical Forum 9 01-10-2009 01:21 PM
Front fork leak mjpliv Goldwing Technical Forum 3 12-15-2004 10:23 AM
