gl1100 water pump replacement parts - Steve Saunders Goldwing Forums
post #1 of 3 (permalink) Old 05-03-2015, 08:43 AM Thread Starter
Model: 1983 gl1100 Standard
A few days ago, i replaced my timing belts, thermostat, radiator hoses, coolant, etc. i knew that replacing the water pump was recommended, but due to the cost and time limitations, i decided against it, since i had no issues. yesterday. i noticed a small coolant puddle under the bike. after a short ride, it seemed to have subsided. next time i went out to the bike, there was a small oil puddle. they both seemed to come from the weep hole under the water pump. it sounds like the water pump and/or oil pump seals are leaking on me. so i guess it's time to replace the water pump and associated seals. i found a water pump and seal kit on cyclemax, but i just want to make sure it includes everything i need, specifically the mechanical seal that seems to be the root cause of this issue. here are the links i was looking at.
http://cyclemax.com/inc/sdetail/gl10...p/29809/159222
http://cyclemax.com/inc/sdetail/gl10...t/29809/158216
do these 2 links include everything i need?
thanks
rv93 is offline
post #2 of 3 (permalink) Old 05-03-2015, 02:20 PM
auctioneeral's Avatar
Year: 81
Make: honda
Model: 1100
everything you need in the 2 links.
But I would keep a eye on the weeping hole and see if the leak goes away. They are know to leak after fluid change and then stop. You can replace O-rings without putting a new pump on it. I just did it to one of my which was leaking and I just replaced all O-rings.
auctioneeral is offline
post #3 of 3 (permalink) Old 05-03-2015, 02:23 PM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
Yes those are what you need.
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
GL1100 Water pump replacement - extra o-ring Stumper Goldwing Technical Forum 2 08-05-2014 03:10 PM
Water Pump Replacement GL1100...done! daveman Goldwing Technical Forum 18 06-25-2010 01:39 PM
GL1100 Water Pump Replacement and Other Items vabikeguy Goldwing Technical Forum 18 10-13-2008 05:43 PM
Gl1100 Water Pump bearing replacement-- 1981 Lew Goldwing Technical Forum 2 02-07-2007 08:30 PM
