Plain old grease or Moly 60 ? - Page 4 - Steve Saunders Goldwing Forums
post #31 of 36 (permalink) Old 07-22-2015, 06:34 PM
Roadyrider's Avatar
Year: 1986
Model: Aspencade, 86000 miles
Reason my wheel flange wore out on my '86 was no grease. The PO used no grease at all. I bought a tube of molly 60, ten bucks at the local stealer.
Roadyrider is offline
post #32 of 36 (permalink) Old 07-22-2015, 07:06 PM
OnaWingAndaPrayer's Avatar
Model: 94SE 209000 miles
Honda M-77 Assembly Paste part# 08798-9010 tube size 2.65oz /1.75g
contains Molybdenum disulfide (1317-33-5j ), Dimethyl, Phenylmethyl-polysiloxane,Trimethyl terminated (63148-52-7 ), 12-Hydroxy-lithium stearate (7620-77-1 )
No mention of the Moly content/ % . I just bought a tube . Its near 20$ at my local stealer and they kept it out back not in the display racks with oils ans coolants ect. My understanding is it is an assembly lube for gears,cams and such internal bits needing good lubricant till the oil flow begins.
Could it work on the splines ? I dunno . I'll keep using Honda PRo Moly 60 for that till its not available.
NASSIR 1
NASSIR 6
NASSIR 7
NASSIR 8
NASR 10 Good times!
post #33 of 36 (permalink) Old 07-22-2015, 07:40 PM
Mike, back up a few posts, M-77 is Moly 60
post #34 of 36 (permalink) Old 07-22-2015, 09:22 PM
mrjay62's Avatar
Location: Palmyra NY Where the men are men and the Sheep are nervous!
Year: 1994
Model: 1500 SE
Send a message via Yahoo to mrjay62
Well guys
From the Dealer here in The Rochester NY area and The one in the Bronx they Both said the samething..
There doing away with Honda moly 60 Patse and Now using the M-77 Assembly Paste..
I also found a few honda OEM Parts sites where I punch In Moly 60 and it shows me a tube of M-77.
I have it, it's gray and smelly im going to try it....
So Confused! ,
mrjay62 is offline
post #35 of 36 (permalink) Old 07-24-2015, 09:36 AM
Year: 1981 1100I [being triked now] 1995 1100 ACE & triked out 1100A
Make: Hondas
Model: 1981 1100i
A word of CAUTION, It is not a good idea to MIX grease products!! Charlie
Aloha Tom likes this.
Charlie in nc is offline
post #36 of 36 (permalink) Old 07-24-2015, 09:57 AM
Year: 94
Model: 1500 SE
that's why we dismantle the bike and install new bearings in a clean work environment, or we clean the bageezus out of any fitting
-such as the plastic speedo drive gear at the wheel hub, Getting 20 year old grease out of the threads and corners of housing, ugh!
reminder, or those new to the thread, MOLY 60 or newer Moly 77 spec is for use on rear wheel splines and driveshaft splines so they slip apart next time!
Wheel bearings use good quality- marine-waterproof synthetic wheel bearing grease. $5 a tub with enough to do 2 bikes and a car
Steering Stem bearings: Use that same grease as wheel bearings
Steering bearings are another common wear-out part, that contributes to our infamous low and high speed tank slapping death wobble
Save your small tube of Moly 60 / 77 for the rear wheel splines and driveshaft, where it will be a lifesaver next time you work on that part of the bike!
Aloha Tom is offline
Why Moly is in our grease??? Racerx Goldwing Technical Forum 15 08-22-2012 10:00 AM
Lumax LX-1918 Gray Lithium Moly EP Grease wb7076 General Motorcycle Discussion Forum 2 05-21-2012 10:33 PM
Moly 60 Vs Syn grease ceasefire49 Goldwing Technical Forum 44 05-02-2012 11:21 AM
MOLY GREASE 396FISH Goldwing Technical Forum 9 07-14-2009 04:03 PM
Drive Shaft Joint and grease quantity - Moly 60 BobbyW Goldwing Technical Forum 5 04-19-2006 08:15 AM
