1500 welded exhaust mod version 1 - Steve Saunders Goldwing Forums
post #1 of 3 (permalink) Old 05-08-2015, 09:38 AM Thread Starter
mike from maine's Avatar
Model: 1995 aspencade se
Ok Here we go. Really simple.
Cut off the end of your muffler at the weld
This is the restriction before....
this is the restriction after. you now will exhaust form the outer chamber as well as the inside chamber
Cut the extension from the turndown evenly on the seam
This little restriction will fall out
Weld turndown back on. I bolted the exhaust together AFTER I welded the one on so I can line up and tack the other one in the right position. I turned mine out a little. Pay attention so you don't weld them on in the wrong position
Sounds good. Deeper sound than I expected. Not loud but sounds good. Will try to post a vid, no promises on that
Update 5/11/15: The exhaust collector has a lot of reverb sound from the decrease in back pressure. Not the sound I am looking for so I made a mod in the collector box with 1/2 inch holes in the internal pipe. It made an improvement so I will be drilling larger holes tonight in hopes to move the exhaust through the collector faster. This is all experimental at this stage and would not attempt this mod if you are thinking about it. The bike is still quiet and my intention is not to make it loud, but give at a nice crisp motorcycle sound. That's how I like my bikes to sound. I will take and post pics of the collector mods. I hope it works well. if it doesn't, I just created a great don't do this story.
Last edited by mike from maine; 05-11-2015 at 10:37 AM. Reason: remove a word.......5/11/15 update
mike from maine is offline
post #2 of 3 (permalink) Old 05-08-2015, 03:23 PM Thread Starter
Going for a ride. Will post conclusion over the weekekn
post #3 of 3 (permalink) Old 05-11-2015, 10:51 AM Thread Starter
not the desired sound I am looking for. Going to do a small mod on the collector. will update on progress when finnished
2012 Gold Wing: USA version vs. Canadian Version Hook General Motorcycle Discussion Forum 12 04-02-2012 09:26 PM
1500 radio mod. DriverRider General Motorcycle Discussion Forum 4 05-24-2011 04:40 PM
Exhaust mod pictures by request LilJack General Motorcycle Discussion Forum 14 03-27-2011 09:13 AM
1500 MP3 Mod toy4rick Goldwing Technical Forum 7 07-27-2009 11:49 AM
97 Mod GL 1500 johnsa General Motorcycle Discussion Forum 2 09-27-2007 12:29 AM
