82 Gl1100 engine swap - Steve Saunders Goldwing Forums
post #1 of 8 (permalink) Old 05-19-2015, 09:12 AM Thread Starter
Rodd's Avatar
Year: 1987
Make: GL1200
Model: 1987 GL1200
I recently purchased an 82 with a bad engine. So I acquired another "good" engine and need to pull the old one and install the good one.
Any good how to's out there on that? I have the service manual so I can follow that. I also figured it would be a good idea to replace the belts before I installed the engine.
Any thoughts?
ImageUploadedByMotorcycle1432044719.379140.jpgImageUploadedByMotorcycle1432044738.446134.jpg
Rodd is offline
post #2 of 8 (permalink) Old 05-19-2015, 09:51 AM
Alaskan Explorer on a Valk
Wilcoy02's Avatar
Year: 1983
Model: GL1100
Clean the oil sump while the engine is out.
Check the neutral switch also.
Wilcoy02 is offline
post #3 of 8 (permalink) Old 05-19-2015, 10:26 AM Thread Starter
Rodd's Avatar
Year: 1987
Make: GL1200
Model: 1987 GL1200
Good idea, I hadn't thought about those.
Rodd is offline
post #4 of 8 (permalink) Old 05-20-2015, 09:59 AM Thread Starter
Rodd's Avatar
Year: 1987
Make: GL1200
Model: 1987 GL1200
OK, I did not get to start on the engine removal last night. So, maybe tonight. Anyway, I ordered the replacement timing belts from Amazon (got both for less than the cost for one at my local NAPA store.) I also ordered new crush washers for the exhaust, and a new oil filter of course. Any other seals or parts I should order to complete this project?
Thanks
Rod
Rodd is offline
post #5 of 8 (permalink) Old 05-20-2015, 10:30 AM
us385south's Avatar
Year: 1996
Model: 1500
I'm your huckleberry!
http://www.ngwclub.com/forum/viewtop...136651#p136651
us385south is offline
post #6 of 8 (permalink) Old 05-20-2015, 12:45 PM Thread Starter
Rodd's Avatar
Year: 1987
Make: GL1200
Model: 1987 GL1200
Thanks! I wasn't sure if the engine removal was the same for both 1000's and 1100's.
Rodd is offline
post #7 of 8 (permalink) Old 05-20-2015, 12:54 PM
Model: 1993 GL 1500
Rodd, looks like a nice project. I pulled the Motor out of my gl1100. There is just a lot of stuff to disconnect and reconnect . If you don't mind my asking, where did you find the new motor. I have been looking around and have not found a good one. My old motor ran but used a lot of oil, if anybody had looked at it they would of thought it was a great motor. So if I buy a replacement I want to make sure it runs before I buy it. It's a big job changing the motors out and I don't want to do it twice. Anyway good luck with the project .
Jerry Burns is offline
post #8 of 8 (permalink) Old 05-20-2015, 01:30 PM Thread Starter
Rodd's Avatar
Year: 1987
Make: GL1200
Model: 1987 GL1200
Thanks. I purchased the motor from One Stop Outlet ( www.onestopoutlet.net ) in PA. There number is 724-783-2393. I live close enough that I drove down and picked the motor up but they will ship them to you.
Rodd is offline
Engine swap, GL1000/GL1100 Clarke Goldwing Technical Forum 2 08-11-2013 03:48 PM
GL1100 engine swap dr.d Goldwing Technical Forum 7 08-13-2011 10:00 AM
GL1100 engine swap glasstat2 Goldwing Technical Forum 11 08-05-2011 08:34 PM
GL1100 Engine Swap Wasawing Goldwing Technical Forum 6 06-29-2011 12:32 PM
GL1000 engine swap into GL1100 joe7580 Goldwing Technical Forum 9 08-22-2010 09:20 AM
