2010 Wing won't crank - Steve Saunders Goldwing Forums
post #1 of 26 (permalink) Old 06-12-2015, 05:12 AM Thread Starter
Wildrat's Avatar
Lightbulb 2010 Wing won't crank
This is my first ever problem with my wing and it shocked me! I had not cranked the bike in two weeks. I did not expect any issues. I turned the key on, hit the starter switch and the motor spun and spun. I turned it off, put a bit more gas in the tank. I already had a 1/4 tank. Turned the key to on, hit the starter and the motor spun again. I spun the motor for 3-4 minutes. No fire. I had to be someplace so I took my Jeep, on the way home I bought some starter fluid. I just wanted to spray a bit down the intake to see if it was even firing. It did not fire. I checked the fuses also which were fine. I won't be able to worry with it for several weeks as I am having vertebrae fused in my neck today.
Your thoughts and suggestions will be appreciated.
Wildrat/Mark
2010 Metallic Black GL1800 Audio Comfort Nav XM ABS model
Darkside #1629 (NRF 195/55R-16 Yokohama AVID ENVigor)
Wildrat is offline
post #2 of 26 (permalink) Old 06-12-2015, 06:05 AM
Do you hear the fuel pump run for a couple seconds when you turn it on?
post #3 of 26 (permalink) Old 06-13-2015, 07:50 AM
SCB
SCB's Avatar
Year: 1995
Model: Aspencade
Not meaning to sound condescending but your description sounds like you just held down the starter button for 3-4 minutes. I hope this isn't the case. You shouldn't crank it continuously for more than a few seconds. If a fuel injected vehicle doesn't start immediately, there's a problem needing to be fixed and continuing to crank the motor will only lead to more problems.
I'm guessing Dave0430 is correct about the fuel pump not priming. Also, will an 1800 turn over with the kill switch in the off position?
Current bikes
'95 GL1500A
'96 Magna (Karen's 3rd bike)
Former bikes
'72 Yamaha DT100 '72 Husqvarna WR250
'63 Sears Allstate Puch '76 Suzuki RM100
'79 RM125 '71 Honda CB350
'77 Honda CB550 4k 94 Kawasaki Vulcan 750
'83 Honda GL1100A '83 Honda GL1100A
'77 Yamaha XS750D '80 Kawasaki KZ1000LTD
'80 SR250 (Karen's 1st bike)
'93 Suzuki GS5000E (Karen's 2nd bike)
SCB is offline
post #4 of 26 (permalink) Old 06-13-2015, 06:21 PM
No it won't.
I was attempting to diagnose the problem with that question, the answer might be a good clue, or at least a starting point. I guess it's not a big enough problem for him to come back with an answer. Not unusual for newbys.
post #5 of 26 (permalink) Old 06-13-2015, 07:29 PM
Model: 88 gl1500
Several things come to mind.
Fuel pump not working (have seen several go out)
Side stand switch(long shot on this)
bones200 is offline
post #6 of 26 (permalink) Old 06-13-2015, 07:32 PM
Foodman's Avatar
Model: 2006 1800
I see you have a 2010 have you replaced your battery.. If the battery is a bit weak it'll crank but won't start
Foodman is offline
post #7 of 26 (permalink) Old 06-14-2015, 05:30 AM
You have never seen a fuel pump in an 1800 go out, I promise.
The side stand switch would only keep it from cranking if it was in gear.
post #8 of 26 (permalink) Old 06-14-2015, 08:20 AM
Model: 88 gl1500
We have replaced 2 fuel pumps on the 1800. One only had 15 psi(but PUMP itself would run but not start). The other would cut out when hot(not start or surge then cut off).
I said the side stand switch was a long shot.
We have seen mice chew wires on bikes and cause all types of problems.
bones200 is offline
post #9 of 26 (permalink) Old 06-14-2015, 11:59 AM
That makes the first 1800 fuel pumps I have ever heard of, they are just like the ones in Honda cars and they never go bad either.
The mice chewing wires was one of my first thoughts and 1 of the reasons I asked if the pump runs when he turns it on, plus the fact it sat for 2 weeks.
post #10 of 26 (permalink) Old 06-14-2015, 12:31 PM
OnaWingAndaPrayer's Avatar
Model: 94SE 209000 miles
Originally Posted by Wildrat View Post
........ I won't be able to worry with it for several weeks as I am having vertebrae fused in my neck today.
I think he has more important issues to deal with , than answering this thread .
NASSIR 1
NASSIR 6
NASSIR 7
NASSIR 8
NASR 10 Good times!
OnaWingAndaPrayer is offline
99 gl1500 won't crank DOC1500 Goldwing Technical Forum 39 03-10-2012 11:45 PM
79 GL1000 Won't Crank Junior Goldwing Technical Forum 6 06-11-2008 11:36 AM
