86 gl1200 no spark on all plugs - Steve Saunders Goldwing Forums
post #1 of 10 (permalink) Old 06-12-2015, 10:45 AM Thread Starter
Year: 1986
Model: gl1200i
Thumbs down 86 gl1200 no spark on all plugs
Hi folks,
I have a perplexing problem getting my goldwing running. I have 12.5 volts at the coils. Coils are good and read 3.2 ohms each.
I've eliminated the kill switch as the issue.
What else could it be. Haven't replaced the plugs yet. My mechanic has own 5 goldwings (he sold me this one) and he can't figure it out either.
Where is the pulse generator on the bike? If i have juice coming into the coils and the coils are good. What else could it be?
THanks in advance for any suggestions!
Dipasqum is offline
post #2 of 10 (permalink) Old 06-12-2015, 11:45 AM
deanbw's Avatar
Model: 86 aspencade
First off I am guessing you did not take this to your mechanic because the word "mechanic" would mean he would know where the pulsars are.
They are behind the timing belt cover mounted around the crank pulley.
unless you had come unplugged or broke both wires, I find it hard to believe both pulsars would go bad.
This leads to bad words, you may have lost the ecm
present bikes
69 honda z50
80 honda z50
80 honda cx500c - sold to daughter,she gave to boyfriend for christmas
86 xl600r - frame up restoration
86 gl1200 aspy - little clean-up just finished
deanbw is offline
post #3 of 10 (permalink) Old 06-12-2015, 12:50 PM
neoracer's Avatar
Model: 87 Aspy,SEI,LTD
what model 86 is this? interstates-aspy's and sei are two different problems
neoracer is offline
post #4 of 10 (permalink) Old 06-12-2015, 01:20 PM
IRAQI RAM's Avatar
Year: 1997 SE
The 86 PGs are behind the timing cover like someone else stated, but their connection is either on the leftside under your gastank cover or just to the left of your battery, It's a 4 wire plug and you can trace it from the front of the timing cover, around the coilpack and then either to the leftside of the fake cover or to the left of the battery.
By the way, the PGs usually fail intermittently at first, you would have a stalled bike when warm refusing to restart until cooled down.
After checking the PulseGenerators, perhaps your IC Ignitor took a dump? It's an easy 5 minute troubleshoot if you have the fake gastank cover off-sounds like you do. Just swap one from a known running bike-borrow a friend's.
IRAQI RAM is offline
post #5 of 10 (permalink) Old 06-12-2015, 04:59 PM Thread Starter
Year: 1986
Model: gl1200i
Thank you all.
It is an interstate @neoracer .
@deanbw , if it is the ecm, is there a procedure to verify this?
@iraqi Sam, funny you should mention that. Last fall it started misbehaving and would lose power at 70 mph at random and I would pull to the shoulder. Wait a couple minutes and then it would fire back up.
Then this spring the starter failed after starting it up a couple times and so I replaced that. Now it's this electrical issue. Is there a way to verify that the cables to the plugs work with a multimeter? Or there's no point because it's the ecm?
Dipasqum is offline
post #6 of 10 (permalink) Old 06-12-2015, 07:01 PM
Does sound like PGs.
Welcome to the forum.
Could I behoove you to put your location and bike model in your profile please?
post #7 of 10 (permalink) Old 06-13-2015, 07:19 AM
neoracer's Avatar
i would buy and replace the pg's now,even if it isn't they will probably go bad in the future and who knows when and if they will become obsolete from honda,seems that alot of stuff lately is going that way i.e. driven flanges
neoracer is offline
post #8 of 10 (permalink) Old 06-13-2015, 11:55 AM
IRAQI RAM's Avatar
Year: 1997 SE
Originally Posted by Dipasqum View Post
Thank you all.
@iraqi Sam, funny you should mention that. Last fall it started misbehaving and would lose power at 70 mph at random and I would pull to the shoulder. Wait a couple minutes and then it would fire back up....
With that tidbit of info, that sounds like PGs going bad. Check them at the plug I mentioned, before you go any further.
post #9 of 10 (permalink) Old 06-23-2015, 12:50 PM
Same symptoms, what's the check for the PG's? resitance, continuity?
1985 GLA
beechum1 is offline
post #10 of 10 (permalink) Old 06-23-2015, 01:48 PM
This is from the Honda manual. PG on yours should be on the front of the engine and the plug is left side under the coils. The book is very unclear about the PGs and I've even read that their numbers are incorrect. But this is the best I can contribute.
E3 Spark plugs on a GL1200 TangSooDoMan Goldwing Technical Forum 8 05-19-2015 04:06 PM
GL1200 will not start - no spark @ plugs giddyupdaddy Goldwing Technical Forum 6 03-05-2014 12:44 PM
No spark front plugs, GL1200 dennisj Goldwing Technical Forum 3 06-18-2013 10:02 AM
No Spark getting to GL1200 Spark Plugs Mr.Mountainman Goldwing Technical Forum 6 09-12-2012 11:17 AM
no spark at plugs GL1200 Interstate napolean Goldwing Technical Forum 16 02-26-2011 04:24 PM
