TC-W3 versus MPG experiences - Page 2 - Steve Saunders Goldwing Forums
post #11 of 22 (permalink) Old 06-19-2015, 03:31 PM
Chromo's Avatar
So is the TC-W3 good to use in chainsaws etc.. that are just normal air cooled 2 cycle? I never tried it in those as it's supposed to be for Water Cooled Outboard 2cycles I think it said. I still been using the over priced big name 2cycle oil in the chainsaw. Cost is not so important as I don't use that much of it, but I never have it when needed or can't find where I put the extra bottles. LOL
It would be handy to just use 1 oil for all the engines.
Chromo
I ride for FOOD
82 1100 riding sometimes, Red
Chromo is offline
post #12 of 22 (permalink) Old 06-19-2015, 03:52 PM
Chromo's Avatar
Originally Posted by flylow View Post
This seems like a win win product. Smoother running engine and 3MPG more in mileage. If you put in 5 gallons per fill up that would be 15 miles more per tank. Two oz per tank is 64 tanks per gallon and that gives 960 more miles for only $12.00 plus the smooth engine. How long will it take to use 64 tanks of gas? At 43 MPG and 5 gallons per tank that's 215 miles per tank. At 64 tanks per gallon of product that's 13,760 miles. I would think that would be a really good riding season or for some of us two really good riding seasons. Sorry about the boring post, as you can tell I don't have a lot to do today so I thought I would play with the numbers for a while. By the way, I'll also be looking to pick up a gallon to give it a try. I have always tracked my gas mileage so if I see an improvement it should show up within a few tanks.
Cool, I never really did all the math up.
960 more miles / 43mpg = 22.33 gals of gas not bought!
22.33gals x $2.50 = $55.83 savings, - $13 for oil = $42.83 savings
Currant prices above for my area now for gas.
I was paying $3.75-$4 gal for gas before it came down.
22.33 x $3.75 = $83.74 savings - $13 for oil = $70.74 savings
So when price of gas was higher and I was running the TC-W3 all the time I saved enough to buy my new front tire before it needed changed!
A FREE new front tire is nice to have!
Chromo
I ride for FOOD
Chromo is offline
post #13 of 22 (permalink) Old 06-19-2015, 04:26 PM
Year: 2008
sooooooo are you going to go back to using it all the time again???? Use it long enough and you can get another rear tire. FREE!
Charlie
flylow is offline
post #14 of 22 (permalink) Old 06-19-2015, 09:53 PM
Bluewaterhooker0's Avatar
Make: Goldwing SE
Model: '97 GL 1500SE
I've been using the TCW-3 oil and Seafoam in every tank for a couple of years, now. Can't say I see an increase in mileage, but I figure it can't hurt regarding fuel pump lubrication, rust preventative for the tank, and upper cylinder lube. The Seafoam I started using to keep the carbs clean. I had a idle speed fluctuation when I first got the bike. Cleared it with Seafoam, but it came back a short while later. Started using the Seafoam in every tank, 3oz. or so, and no problems since. Seems to me the bike did seem a little smoother with the oil addition, but it's been so long now, I can't tell the difference. I also use non-ethanol gas whenever possible, which is most of the time. Problems with 2-stroke mini engines turned me against ethanol gas a long time ago.
Thomas Paine December, 1776
Bluewaterhooker0 is offline
post #15 of 22 (permalink) Old 06-20-2015, 10:30 PM
Model: 88 gl1500
I am wondering what percentage or ratio would be ideal to run in the tank. The tank holds around 6 gallons. I don't think 1,2 or 3 oz. is enough to even check.
32:1 is 4 oz. per gallon.
I am starting to run 32:1 mix in ALL my equipment around the house. 4 stroke or 2 stroke. Doesn't seem to hurt. My lawnmower seems to run better with that.
But I am using regular 2 cycle mix with that. Not sure what the TWC-3 difference is. Does it measure the same? I know some oils say 50:1 ONLY.
Just trying to see what I can try on my long trip coming up. Need a few more MPG's! Just like been said. I was 36-42 Nothing consistent with every tank.
bones200 is offline
post #16 of 22 (permalink) Old 06-20-2015, 10:42 PM Thread Starter
My chain saw states 2 oz per gallon, and so far, it has made 3 seasons...
When I worked on the county road crew, we used 2 oz per gallon in all of the Stihl brand weed eaters.
For the Goldwings, I think 2 oz per tank is enough.
post #17 of 22 (permalink) Old 06-20-2015, 11:55 PM
CrystalPistol's Avatar
I did it for a couple years, used empty large StaBil plastic container with the measuring dispenser to add it to fuel at stops. The ratio according to all I could find was 1 OZ. TC-W3 to every 5 gallons. More returned same results, less didn't help ..... an ounce to 5 gallons seemed to be the magic ratio.
I plan to start back with it after falling off the wagon.
...(Candy Spectra Red )
CrystalPistol is offline
post #18 of 22 (permalink) Old 06-21-2015, 01:45 AM
Chromo's Avatar
I still run it often, forget sometimes or just out, and other times I am trying to get a handle on MPG without it in set trips
Chromo
I ride for FOOD
Chromo is offline
post #19 of 22 (permalink) Old 06-21-2015, 01:51 AM
Chromo's Avatar
2oz per tank fill got me 3mpg extra.miles. Maybe 3 or 4 oz would get more extra miles, but I would not want to run too much and foul my plugs or have smoke or such.
Chromo
I ride for FOOD
Chromo is offline
post #20 of 22 (permalink) Old 06-21-2015, 12:39 PM
SCB
SCB's Avatar
Year: 1995
Model: Aspencade
A word of caution regarding mixing ratios in 2 cycle engines, learned at the school of hard knocks. I have an 60hp Evinrude on my boat. A few years ago I failed to keep track of mixing oil when I refilled the tank. I know there were times when I would fill up on the way to the lake and couldn't remember if I added at the pump. Figuring better safe than sorry, I added it at the lake. It finally caught up with me when the motor dropped a cylinder while pulling tubes. I figured I had mixed it too rich and fouled a plug. Pulled the tubes in and headed for the launch. I thought maybe running it full throttle would clean it out, and I ended up seizing the engine. After having it rebuilt the mechanic explained that he sees more motors seized with too rich oil/gas ratios than motors run without oil. The carb passages on mine clogged up and without the fuel mixture going in, one of the cylinders ran dry and seized up.
$1200 lesson learned, I now pay close attention to the mixing ratio. I use a 5 gallon can for my 50:1 equipment and when it's getting low enough that I'm not sure I'll have enough to finish the day, I pour the contents into my vehicle so I can make sure the new fuel has exactly a 50:1 ratio. Never had a problem this way and I figure running a little 2 cycle oil in the car is kind of a treat.
Current bikes
'95 GL1500A
'96 Magna (Karen's 3rd bike)
Former bikes
'72 Yamaha DT100 '72 Husqvarna WR250
'63 Sears Allstate Puch '76 Suzuki RM100
'79 RM125 '71 Honda CB350
'77 Honda CB550 4k 94 Kawasaki Vulcan 750
'83 Honda GL1100A '83 Honda GL1100A
'77 Yamaha XS750D '80 Kawasaki KZ1000LTD
'80 SR250 (Karen's 1st bike)
'93 Suzuki GS5000E (Karen's 2nd bike)
SCB is offline
01 versus 02 rayjoe General Motorcycle Discussion Forum 2 05-12-2015 06:55 PM
GL1200 Rotor Thickness Experiences zooklm Goldwing Technical Forum 7 10-17-2012 12:44 PM
Evaporative cooling vests - your experiences? Shiny_side_up General Motorcycle Discussion Forum 28 04-21-2011 04:13 PM
need some opinion and experiences dbergeron General Motorcycle Discussion Forum 53 02-03-2007 06:42 PM
MAC Exhaust Systems: Anybody here have any first hand experiences? boxerdad Goldwing Technical Forum 4 12-19-2005 10:46 AM
