GL1500 won't start, won't crank, no headlights. - Page 3 - Steve Saunders Goldwing Forums
post #21 of 25 (permalink) Old 07-02-2015, 08:07 PM
Chromo's Avatar
Originally Posted by G'man View Post
Oh, and Chromo, we live about as far from you as we can and still be in Missouri. We live in the NE corner, but it's only a 7 hr drive from you. So why ain't we riding? I'm envious of the great rodes you have in Arkansas. Keep safe.
YA lots of people say that to me. Then add wish it could be even further!
Well I ain't been getting out for any big rides yet this year do to some issues, about 200 miles or a bit more been my day limit moslty.
Maybe we'll meet up though when I start runing those 500-900 mile days again soon.
Ya, it's funny sometimes how the smallest wire can keep something BIG from working.
Then again for allot of things like a relay it only takes a tiny wire to trigger it then the relay sucks the big power from battery to power the big device using big wires.
So a little wire breaks and relay does not trigger!
I had allot of 12V stuff wired up to run off a remote control unit. Little stuff ran direct from the 10amp relays in the controller, for the big stuff the controllers 10amp relays only sent power to external 30AMP relays to trigger them which then powered the big stuff.
One day all my big stuff was DEAD but the little stuff still worked.
YEP, I had 1 ground from battery to all 30Amp relays and it busted somehow so none of the 30's would trigger.
Chromo
I ride for FOOD
82 1100 riding sometimes, Red
Chromo is offline
post #22 of 25 (permalink) Old 07-02-2015, 08:11 PM
Chromo's Avatar
Disconnect the motorcycles battery and jump directly to the cables, I've seen a lot of times a bad battery foil a jump start.
Ya, that's probably what happened when I was trying to start the 82.
I got the battery out now again, had to put it back into the 1500.
I think I will try jumping 82 again without the battery and see if that works on it now.
Chromo
I ride for FOOD
Chromo is offline
post #23 of 25 (permalink) Old 05-26-2016, 06:33 PM
+! for what Dave said especially if the neutral light won't come on when in neutral. Just flip flop #3 with any other relay to test it. If no luck then look at the reverse switch. Most likely #3 relay though.
Where is the #3 relay located?
Thanks
sonex772 is offline
post #24 of 25 (permalink) Old 05-26-2016, 07:51 PM
Thanks
I suppose you mean for a 1500, it's in the fuse box, upper right corner.
post #25 of 25 (permalink) Old 02-20-2018, 06:37 PM
I know this thread is pretty old...but didn't stop me from really benefiting from it. Thanks to everyone for your suggestions. I replaced the reverse switch like everyone said was likely the culprit and it didn't make any difference. Came back on the site to scan for some more suggestions and found the fuse relay problem. Swapped out #3 with #2 and VIOLA is came on and, after sitting for five months, it fired up in about 15 seconds of pushing the starter. Love my '92 Wing and thanks again to everyone!!!
J Strat is offline
GL1500 won't start, no neutral light, headlights. TronPlayer Goldwing Technical Forum 7 09-03-2012 03:59 PM
99 gl1500 won't crank DOC1500 Goldwing Technical Forum 39 03-10-2012 11:45 PM
1985 GL1200 Won't crank, start or turnover RonSena Goldwing Technical Forum 27 04-23-2006 04:03 PM
crank's but won't start or keep running !!! glassman Goldwing Technical Forum 24 04-03-2006 06:18 AM
