Radiator fan hitting shroud after Poor Boy Conversion. - Steve Saunders Goldwing Forums
 4Likes
  • 1 Post By neoracer
  • 1 Post By CrystalPistol
  • 1 Post By Charlie in nc
  • 1 Post By AZgl1800
post #1 of 9 (permalink) Old 07-01-2015, 09:56 PM Thread Starter
mark4Jesus's Avatar
Model: '86 Aspencade
Finishing up on my Poor Boy Conversion. When I installed the radiator and got the electrical hooked up I ran the fan to make sure that it would not contact the radiator, and it did not. Started the bike and everything was fine; however, when the engine heated up the fan started contacting the shroud. When engine was cold there was no contact. The fan blade was contacting the shroud at the 1 o'clock area. I used a screwdriver and pushed the shroud up and the contact moved to 11 o'clock! Engine was hot, not overheated, and it made it difficult to do much. I am going to try again tomorrow when I get home and the engine is cool.
I sure hate to pull the radiator again. Any ideas on what to do? I though about trimming the blades, but if I don't get them trimmed evenly, I am afraid it will induce vibration. Of course it might be impossible to trim with it installed.
1986 Aspencade 75,700 miles
Past Bikes
1987 Interstate (Had to sell to get money to replace a truck that was stolen, sad day!)
1980 Kawasaki LTD 440
2005 Honda Reflex (I guess this counts)
mark4Jesus is offline
post #2 of 9 (permalink) Old 07-02-2015, 03:06 AM
neoracer's Avatar
Model: 87 Aspy,SEI,LTD
i'd just trim the blades if that's what needed,considering to amount of time the fan actually runs,dont think that imbalance would be a problem,once you take the fan off you may see what the real problem is
mark4Jesus likes this.
neoracer is offline
post #3 of 9 (permalink) Old 07-02-2015, 05:41 AM
CrystalPistol's Avatar
I believe trimmimg the fan blades is part of the deal ..... as I recall.
...(Candy Spectra Red )
CrystalPistol is online now
post #4 of 9 (permalink) Old 07-02-2015, 07:13 AM Thread Starter
mark4Jesus's Avatar
I may have overlooked that step. Now that you mention it, it seems like I read that somewhere. I know after all of the adjustments if was fine and then when installed and cold it was fine. Started after warm up. I hate to take the radiator back off, but if I must. It would probably be faster to take the radiator off than to try to fix it place.
Past Bikes
post #5 of 9 (permalink) Old 07-02-2015, 10:51 AM
Year: 1981 1100I [being triked now] 1995 1100 ACE & triked out 1100A
Make: Hondas
Model: 1981 1100i
On my 81 I, I had to trim the blades, Cut one Blade then use it as a pattern for the rest of them, Charlie
Charlie in nc is offline
post #6 of 9 (permalink) Old 07-02-2015, 11:26 AM Thread Starter
mark4Jesus's Avatar
Thanks guys. I guess the radiator is coming back out!
Past Bikes
post #7 of 9 (permalink) Old 07-02-2015, 08:56 PM Thread Starter
mark4Jesus's Avatar
Pulled the radiator and trimmed the fan blades. Put everything back together and fan ran great. Idled until it had 5 bars on the temp and started fan. No rubbing and cooled the engine. Now to finish the mods on the left fairing.
Thanks for the help guys!
Past Bikes
post #8 of 9 (permalink) Old 07-05-2015, 10:04 PM Thread Starter
mark4Jesus's Avatar
Poor Boy complete! Test road this evening and everything was great! Thanks for the help and encouragement! It sure felt good to be back on the bike again!
Past Bikes
post #9 of 9 (permalink) Old 07-05-2015, 10:05 PM
I know that you will be having a lot of Smiles on your bike now...
and with nary a thought about loosing the stator again.
poor Boy conversion? Value afterwards? dtherren General Motorcycle Discussion Forum 4 09-12-2013 01:30 PM
Poor boy conversion ceasefire49 Goldwing Technical Forum 25 10-27-2011 11:06 AM
poor boy conversion jbunn Goldwing Technical Forum 4 07-14-2008 05:56 PM
Poor Boy Conversion limo$mitch Goldwing Technical Forum 21 05-16-2007 10:18 PM
Poor Boy Conversion limo$mitch Goldwing Technical Forum 1 04-16-2007 04:26 AM
