Getting locked out of my GL1800 trunk - Steve Saunders Goldwing Forums
post #1 of 13 (permalink) Old 07-03-2015, 05:13 AM Thread Starter
Year: 2003
Model: Gl1800
Thumbs down Getting locked out of my GL1800 trunk
Hi there
This is my first thread. Could not find proper answer on existing thread having a spécial problem with my bike. (2003 gl 1800, 79000 km)
Was at a dealer nearby last night to ask for help...but he and his mecanics had never heard of it: my back trunk and side ones all lock by themselves...after about 10 seconds after being unlocked with my key.
Tried different things but don't seem to find the solution to this.
Any ideas anyone?
Other question: looking to upgrade to more recent version. (To get heated grips and seat, integrated GPS and more???)
Is worth the price? My ride still looks good and is well equiped except for these accessory. Was told by the dealer that the more recent versions are better built. Your comments please.
thanks a lot.
Elpe is offline
post #2 of 13 (permalink) Old 07-03-2015, 06:53 AM
Later versions are "better built"?
ummm, that is just sales talk. the guy is looking to better package his wallet.
I just bought a "brand new" 2002 model with 98,000 miles on it and it runs just like a brand new machine.
Unless you just have an innate desire to be the kid on the block with a brand new title, and willing to absorb a huge depreciation in value on your machine.... I would forget the sales pitch and continue to enjoy your bike.
The "new versions", ie, those built from 2012 and later have different plastics on them and look slightly different; but apart from that, nothing there that would entice me to buy a new one.
Heated grips you can purchase and install yourself and save about $30,000
Now, as to your trunk and side pockets locking after being unlocked, I don't have a clue.
But it has to have something to do with the keyfob locking package.
post #3 of 13 (permalink) Old 07-03-2015, 07:09 AM
Wonder if this has anything to do with it? Does not mention unlocking with the key.
If the trunk opener unit is unlocked using the
transmitter but any of the lids is not opened
within 30 seconds, the trunk is locked
automatically.
post #4 of 13 (permalink) Old 07-03-2015, 08:26 AM
joe in calif's Avatar
When you open it with the key it should stay unlocked, that is a weird one. Unlock it with the FOB and open the trunk fir about 30 seconds and then shut it and see what happens.
Also is the FOB near when this happens? I'm wondering if there is a problem with the FOB and it is locking the trunk & bags.
Try putting in the house away from the bike and see what happens
Your dealer of course is trying to make a sale but the early 1800 wings, 2001 - 2004 did have a lot of problems. Frame cracking, over heating and here are a few more. 05 up saw a lot of these fixed but there are still recalls on some or rear brakes locking up. Some have had "ghost shifting", (tranny popping out of gear) but in 2013 I think Honda finally changed the gears and now this is O.K.
I had 2 1800 wings, an 02 and an 08. I had the frame re-weld completed on the 02 and had zero problems except for a rear tail light housing replaced on my 08, some bikes will have a lot of issues some will have a little.
The Honda factory GPS is not that great, very limited to what you can do. You would be better off going with an after market Garmin, updates are cheaper and easier to use.
SB 19 2006 Airbag CB Radio Squeal (December 2006)
SB 18 2003-2004 Frame Weld Recall (February 2005)
SB 17 2001-2002 Frame Weld Recall - Revised (April 2005)
SB 16 2002-2004 LBS PCV Leakage Recall (February 2005)
SB 15 2001-2008 Trunk Opener Unit - Revised (October 2007)
SL 14 Audo Component Exchange/Repair (June 2005)
SB 14 2002-2003 Frame Weld Recall (September 2003)
SB 13 2001-2003 ECM Replacement-Cooling Improvement (June 2003)
SB 12 2002-2003 Bank Angle Sensor Mounting Screws Recall (December 2002)
SB 11 2001-2003 CD Changer Replacement - Revised (November 2007)
SB 10 2001-2002 CB Radio Replacement (January 2002)
SB 9 2001-2002 Speed Sensor Wire Clamp (December 2001)
SB 8 2001 Speedometer Repair (December 2001)
SB 7 2001 Oxygen Sensor Replacement (October 2001)
SB 6 2001-2002 Rear Tire Inspection (October 2001)
SB 5 2002 Reverse Cable Adjustment (September 2001)
SB 4 2001 Radio Muting Improvement (June 2001)
SB 3 2001 Crankshaft Pulse Rotor Recall (May 2001)
SB 2 2001 Engine Stop Switch Recall (May 2001)
SB 1 2001 Coolant Temperature Guage (December 2000)
A NEW START ON 1/20/2017
joe in calif is offline
post #5 of 13 (permalink) Old 07-03-2015, 08:34 AM
There is a micro switch that lets the ecm know that your bags are open or closed could be bad or out of adjustment.
post #6 of 13 (permalink) Old 07-03-2015, 01:52 PM
Year: 2008
+1 move your remote into the house or remove the remote battery, could have a stuck button/switch.
bones200 likes this.
Charlie
flylow is offline
post #7 of 13 (permalink) Old 07-03-2015, 08:02 PM
Model: 88 gl1500
I was going to say remove or replace the battery in key fob.
I have seen the fob NOT open the trunk, but not lock it by itself..
Worse case is to unplug the electric lock and always use it with key. I don't suggest "BUYING" a newer bike. Have seen the 1800 go over 300,000 miles if taken care of. If your happy with the bike, keep it...ESPECIALLY if it is PAID FOR!!!!
bones200 is offline
post #8 of 13 (permalink) Old 07-04-2015, 05:59 AM
The transmitter will work from a long way off with a good battery in it, and it should sound the horn and flash the lights if the FOB is locking it.
I would remove the inner panel from the trunk lid and check if the white wire to the control unit is grounded.
post #9 of 13 (permalink) Old 07-08-2015, 09:47 PM Thread Starter
Year: 2003
Model: Gl1800
Should the white wire be grounded or not? Knowing what should it be, I Will definitely look into it.
Thanks Dave.
In the meanwhile, all I have to do is unlock the trunk with the key and the trunk keeps unlocked this way....
Strange...
Whenever I use the fob to unlock the trunk it locks itself within 10 seconds.
Elpe is offline
post #10 of 13 (permalink) Old 07-09-2015, 12:18 AM
mikesojourn2's Avatar
Model: 2012
I've had my bike for almost 3 years and never used the Fob yet. After reading this thread, I want in the house and found he Fob and it actually works. Scared the crap out of me when it blew the horn in the garage though.....
mikesojourn2 is offline
GL1500 Locked Trunk! Blackhat Reference and FAQ Forum 116 03-31-2015 02:00 PM
GL1500 locked trunk odskaggs2 Goldwing Technical Forum 5 11-07-2011 05:22 AM
GL1500 trunk lid locked Brettchuk Goldwing Technical Forum 9 04-18-2011 02:06 PM
Locked up Trunk - can't open Bud Stocks Goldwing Technical Forum 2 02-22-2009 11:01 PM
GL1500 Trunk Locked Eshuman General Motorcycle Discussion Forum 10 04-21-2006 09:00 PM
