Mil/dtc f1-14.. - Steve Saunders Goldwing Forums
post #1 of 2 (permalink) Old 07-03-2015, 08:40 PM Thread Starter
Model: 1800
Mil/dtc f1-14..
Hi All:
My 2002 Goldwing with only 64xxx miles is flashing a code. The F1 light appears to be telling me I have issues with the #3 cylinder/Injector (F1- Code 14) The Bike runs and idles fine. But the presence of the light makes me nervous that there IS something wrong.
I have tried to reset the MIL by shorting the plug on the DTC, but it didn't work. Now I am faced: with a trip to the Stealership and a $100.00 diagnostic fee.
If you have a hint or an idea as to how I can fix this, sing out! I appreciate your help, in advance.
Perry
Perry45 is offline
post #2 of 2 (permalink) Old 07-03-2015, 09:53 PM
Model: 88 gl1500
You can try this(it works on cars).
Disconnect the negative battery cable( and ALL wires attached example: lights and gadgets), WAIT 5-10 MINUTES, then TOUCH the negative CABLE(use screwdriver or anything conductive) to the positive terminal WITHOUT TOUCHING THE NEGATIVE BATTERY TERMINAL!!, THEN reconnect the negative cable to the battery terminal. This should erase the codes.
The DLC short should do the trick IF you follow the procedure in book.
The you can ride it and see if it comes back on.
bones200 is offline
GL1800 FI mil #25 PROPITIATED Goldwing Technical Forum 4 05-20-2013 10:55 AM
gl 1800 mil code cycleman0622 Goldwing Technical Forum 2 04-30-2011 06:51 AM
Wanna see a $5.5 Mil Mustang? UbarW Miscellaneous Forum 17 11-24-2009 07:11 AM
The $66 MIL Goldwing Okiebryan General Motorcycle Discussion Forum 15 11-11-2007 05:57 PM
